engine serial number - where to find
Old Mar 16, 2009 | 03:07 AM
germany's Avatar
Question engine serial number - where to find
good morning,
can somebody please give me a response, where I can find the serial number of the engine?
Thanks
Michael
Old Mar 16, 2009 | 07:39 AM
wildbill's Avatar
It would be on the ECM.
Old Mar 16, 2009 | 09:18 AM
germany's Avatar
The ECM? What or where is that?? Thank you
Old Mar 16, 2009 | 09:28 AM
wildbill's Avatar
Be on the right side of the engine block (facing the front). Be square and have to big electrical connections.
The ECM (Engine Control Module) uses various sensor inputs for emissions control.
Old Mar 16, 2009 | 11:53 AM
Cummins97's Avatar
On the engine! Sorry I had to.
There should be a metal tag on the timing case with it on there. Pretty much right in front of the injection pump.
serial number location
Old Mar 16, 2009 | 05:45 PM
ykdave's Avatar
If you have a 12v with an ECM you had better get your brain or the engine checked out!
Its all mechanical, the closest thing to an ECM in the truck is the PCM which controlls next to nothing to do with the engine (grid heaters basically)
On the gear train cover on the drivers side (directly infront of the inj pump) you will find a metal tag on there with the ESN, along with various other engine specs (timing/valve lash/smog)
Old Jan 20, 2012 | 11:57 AM
RollingD34th's Avatar
so what would you do if some hack (aka, the previous owner) replaced the engine (cause he blew it up with hacked up engine mods) and lost the tag for the new engine? (which might actually be a '93 >_>)
Old May 28, 2014 | 08:09 PM
Da Bomb's Avatar
I'm having the same problem--finding the serial number plate for my engine. It's a 2005 Cummins 24V HO: not on valve cover, not near exhaust, not near oil pump, not near timing cover (I've been told to look at all those places). I have the VIN, but neither Dodge, nor Cummins can give me any info on the engine's SN. Any suggestions?
Old May 31, 2014 | 10:31 PM
4x4manonbroke's Avatar
LMAO !!!! on a 12V ... , you must be kidding me !!!!
My stereo system has more computer parts than the rest of my entire truck (95) ... LOL
Old Feb 15, 2016 | 07:32 PM
uzkimes's Avatar
Default engine serial nr look up by vin
https://quickserve.cummins.com/info/index.html create free owners acct and use VIN to ESN refference on the left.super easy
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
hershwork
Mar 1, 2015 05:15 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Nov 12, 2014 06:10 PM
