Converting an auto to manual
Old Mar 14, 2009 | 10:36 AM
Cody Cummins's Avatar
Default Converting an auto to manual
Just wanted to know how much it would cost to convert my truck into a manual
Old Mar 14, 2009 | 09:58 PM
12valvetater's Avatar
im not sure if the cross member would line up right since the auto is longer
but youll need clutch flywheel 500 and up to about a grand. tranny 700 from a junk yard if you can find one 1800 for a remaned. driveshafts. slave cylinder master cylinder and plumbing clutch pedal and linkages. and you have to cut a bigger hole in the floor.
Last edited by 12valvetater; Mar 14, 2009 at 09:58 PM. Reason: Automerged Doublepost
Old Mar 15, 2009 | 10:43 PM
94cummins12v's Avatar
its on average 4 grand to do a swap
Old Mar 15, 2009 | 11:37 PM
stkdram55's Avatar
my friend with a 3850 South Bend DD clutch, had about 5k in his
Old Mar 16, 2009 | 09:59 AM
kazairl's Avatar
helps if you can find a wrecked donor truck. Then you can swap in the parts you need and sell the rest. It also depends on which manual your thinkin of swapping in.
PapaDaus
Jul 5, 2015 08:10 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
1ATony
1A Auto Parts
Dec 1, 2014 09:34 AM
Jgloveracob
Nov 16, 2014 07:27 AM
