engine cranks too long
Old Mar 13, 2009 | 05:05 PM
mikew's Avatar
Default engine cranks too long
does anyone know what the fuel pressure should b for a 2003 dodge cummins stock transfer pump it seems like my truck cranks a little too long before it fires
Old Mar 13, 2009 | 05:29 PM
skynyrd's Avatar
check the rail pressure relief valve they tend to allow fuel pressure to blead off while trying to start the truck.
Old Mar 13, 2009 | 05:37 PM
mikew's Avatar
whare would that b
Old Mar 13, 2009 | 06:03 PM
skynyrd's Avatar
the rail pressure relief valve is right next to the rail pressure sensor if you take the banjo bolt out of the top of the relief valve and install a set screw to plug the return it definitely helped with mine.
Old Mar 13, 2009 | 09:03 PM
Cumminsdieselboy's Avatar
Do you leave the plug in?
Old Mar 14, 2009 | 01:48 AM
atrd86's Avatar
A silly but simple suggestion, had a similar issue noticing my truck took a little longer than my dads truck to start for the last while and I looked into everything, than I replaced my batteries 2days ago and everything is normal now. My truck always started and the batteries were high end 8yr free replacement 900ccAmps so I never considered them, just tried it as a last ditch effort and it worked.
Old Mar 14, 2009 | 07:37 AM
madhat's Avatar
There was a long crank TSB out, I cannot remember what years it was for.
The batteries are a good idea, and so is the rail pressure relief valve.
Old Mar 14, 2009 | 09:25 AM
wildbill's Avatar
Brand new one puts out 8 psi and 70-80 gph. But it's not fuel pressure, it's volume that matters.
Old Mar 14, 2009 | 10:48 AM
mikew's Avatar
i will try the relief valve because i just put 2 new batteries in it last week
Old Mar 14, 2009 | 09:13 PM
06 DIESEL's Avatar
Here is a link to the thread about capping the relief valve.
https://www.dieselbombers.com/5-9-li...fuel-rail.html
burndiesel
10
Feb 7, 2023 01:15 AM
cmine615
Diesel Engine Conversions
14
Apr 3, 2017 09:12 PM
klein444
Jun 20, 2015 11:48 PM
dandbmcc
Mar 14, 2015 11:05 PM
metal_miner
Dec 23, 2014 11:40 PM
