what should boost be limited at
Old Mar 12, 2009 | 12:17 PM
Diesel Roughneck's Avatar
Default what should boost be limited at
i just put on a bd super b single. and a new Jasper long block in an 05, w 6 gun, intercooler, nipple, meth inj, intake, 5"turbo back, bosch stock but upgraded sticks.
my question is jasper gives an upgraded head gasket and i have 2000 mi on it now and i have the turbo limited to 30p. what can i safely get away with for now?
oh and i dont know much about bd turbos my shop that i have dealt with for years said this was the way to go
Old Mar 12, 2009 | 02:38 PM
wildcat's Avatar
I don't think your computer defuels or throws a code until around 44 PSI...
I also don't think the head gasket or intake valves are in jeopardy until around 60PSI.
Maybe contact Jasper and see what they have to say?
Also, get the turbo map for your turbo and find out what the upper limit of it's efficiency range is...
Old Mar 12, 2009 | 03:24 PM
sounds good do you know were i might find map at
Old Mar 12, 2009 | 03:48 PM
nmlakerat's Avatar
check BD site or call they should be able to provide it.
Old Mar 12, 2009 | 03:51 PM
wildcat's Avatar
Send a PM to BDPowerDave, see if he can help you out.
He is here on this board.
Old Mar 13, 2009 | 12:13 PM
thanks guys for your impute i had to call BD and they said 45psi. also i have a six speed so as far as i know a map wont do me any good.
Old Mar 13, 2009 | 03:05 PM
wildcat's Avatar
That's cool.
I'm glad you got the right answer to your question!
Old Mar 13, 2009 | 05:16 PM
jasper said that stock can only push 20-25psi but i was pushing alot more than that when my truck was stock
Old Mar 13, 2009 | 05:48 PM
wildcat's Avatar
Well, at least you ended up with someone who knew what they are talking about!
My truck Stock would do 30, then back off to 28 PSI.
With the Smarty and WG disabled, it goes up to 44 PSI, still with the stock charger and injectors...
You should fill out your signature line and hang out here for a while...
I didn't know you had a stick until you told us...
Old Mar 15, 2009 | 10:21 PM
sorry guys i did fill out my signature line but for some reason it wont come up
