some help.
Old Mar 11, 2009 | 11:27 PM
navalseabee's Avatar
Default some help.
i wanna do the KDP fix on my truck just for piece of mind, some advice before i do it, tips tricks,?
Old Mar 11, 2009 | 11:37 PM
392hemix's Avatar
make sure you be careful not to break your crank postion sensor, its 125 bucks for a new one and wont run right without it, make your own tab its easy and cheap, i have pictures of mine in my profile if you want to take a peak.
Old Mar 12, 2009 | 05:30 AM
Jazz's Avatar
Maybe this will give ya some help https://www.dieselbombers.com/cummin...deo.html:U::c:
Old Mar 12, 2009 | 10:22 AM
xzaq103's Avatar
FormerVendor
Might also look here.
Installation Instructions
Old Mar 12, 2009 | 10:49 PM
how much time am i looking at here to do this thing?
i looked here and it said theres more than one? is this true or did i miss understand?
Last edited by navalseabee; Mar 12, 2009 at 10:49 PM. Reason: Automerged Doublepost
Old Mar 12, 2009 | 11:29 PM
94cummins12v's Avatar
one killer dowel pin, two dowl pins total but you dont have to worry about the bottom one it isnt in the gear case, it did mine whil ei was overhauling my engine but it shouldnt take more than 3 hours, i help on one of my budies 98 12 last month he did the work i did the directing
Old Mar 18, 2009 | 06:56 PM
is it a total bear to do in the truck with the radiator and intercooler in?
Old Mar 18, 2009 | 07:43 PM
12valvetater's Avatar
you have to pull the bumper radiator intercooler fan and gear cover its a nce saturday project
Old Mar 18, 2009 | 08:13 PM
392hemix's Avatar
I did mine without even tackin the fan shroud off., just pull the fan off, and you can get to everything, i would also recomend takein the upper radiator house off, it onley took me 2 hours to do, would of been quicker if i didn't break my cps and i also made my own tab! Just take your time and watch what your doing.
Old Mar 19, 2009 | 03:57 AM
97cummins's Avatar
I didn't have to remove the bumper when i had mine done.And if you take out your radiator and intercooler while doing the job,blow out both of them to.That'l help the engine run a little cooler.
