tire wear
Old Mar 11, 2009 | 11:18 PM
392hemix's Avatar
Default tire wear
How do i change camber in my 97 4x4 2500? i am destroying the out sides of the tires? looks to me like i have to much positive camber? is this something i can adjust? or do i have to do it by buying special degree ball joints? its cold and wet up here in nh, so i havent looked @it to c what i need to do
Old Mar 12, 2009 | 12:11 PM
dieselmadscientist's Avatar
could by toed in alittle bit that could cause the outside of your tires but i don't think you can adjust your camber very easy
Old Mar 12, 2009 | 12:13 PM
stkdram55's Avatar
no i dont think you can adjust your camber, just toe in and out is about it
Old Mar 12, 2009 | 12:47 PM
there are shops that can bend axles to adjust camber on solid beams
Old Mar 12, 2009 | 12:54 PM
392hemix's Avatar
****, well i guess i will get the toe plates out and see what stanely says hope the toes out and i can make an easy fix out of it....
Old Mar 12, 2009 | 01:10 PM
kazairl's Avatar
It is probably more of a toe issue. The only way camber can change on these trucks is to bend the axle(been there done that) but that usually results in a negative camber gain not positive.
Old Mar 12, 2009 | 03:47 PM
392hemix's Avatar
i will have to figure something out, its pretty bad, gonna check the toe when it warms up, and i will see what i am dealing with. i still think you can change camber with degreed ball joints? nothing is easy.
yfzrunner
Sep 17, 2015 05:23 AM
corksil
Jun 30, 2015 06:58 AM
dallasca
28
May 26, 2015 12:58 AM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
veggyoilkid
Tire, Wheel & Suspension
Nov 5, 2014 01:34 PM
