differental Q's
Old Mar 11, 2009 | 03:54 PM
beagle2@galaxycable.net's Avatar
Angry differental Q's
is there any way to turn my limited slip into a posi trac
Old Mar 11, 2009 | 03:59 PM
SeaDrive's Avatar
It already is Posi-Traction was just a name brand of limited slip. If you mean to completely lock it (not for street use) then a mini-spool or locker could be installed.
Old Mar 11, 2009 | 04:27 PM
ill tell ya this i went to turn around in a field and burried the passenger side of the truck. neither of the driver side tires would turn. i want all 4 wheels spinin when im in 4wheel drive not 2
Old Mar 11, 2009 | 04:39 PM
The best option is a selectable locker like an ARB. That way you can lock it all up when you want/need it and unlock it for when your on the street. Most people dont want a spool or detroit:
Air Lockers
Old Mar 11, 2009 | 05:18 PM
does anyone run air lockers on there truck, and if so are they any good
Old Mar 11, 2009 | 05:50 PM
Theyre good - no doubt about it.
About $900 per diff
Old Mar 11, 2009 | 07:22 PM
JKM's Avatar
JKM
I have air lockers on my Mack , does that count?
Old Mar 11, 2009 | 07:24 PM
SeaDrive's Avatar
It sounds to me like both diffs are open in your truck or at least the rear's limited slip isn't working. Sounds like an ARB could be a way to go or have your limited slip serviced. I'm no 4WD expert but I'm not aware of too many Dodges with limited slip front axle.
Old Mar 11, 2009 | 09:00 PM
Beets's Avatar
i am not positive but you would probably be better of getting a Detroit true trac. it is a gear driven limited slip will last much longer then a normal LS selectable lockers are expensive. I am not positive if they make a true trac for a dana 70 or 80.
Old Mar 11, 2009 | 09:02 PM
ykdave's Avatar
probably just worn out clutches. from what i hear they can be set up alot better also.
BTW positraction was just GMs marketing name for limited slip, much like trac lok, gov lok, twin traction ect...
The posi name just seemed to stick though
