Cylinder wear???
Old Mar 10, 2009 | 08:39 PM
392hemix's Avatar
Default Cylinder wear???
I Understand that when your truck is "rolling coal" it is because you are not burning all the fuel. When i am putting my truck under load, it black smokes and then clears up pretty quick. So my question i think is a simple one, How bad is it for these motors to be black smoking or running ritch? is it enough fuel to wash out my cylinders? can i do this and not worry because it is fun to spool up and shoot people with soot, but i don't want to damage my motor.....i run good oil and change it frequently so i think i am fine but wanted everyones opinion.
Old Mar 10, 2009 | 08:45 PM
Whit's Avatar
Site Mascot
yer not hurtin it...........when the boost pressure hits the combustion chamber is when the air to fuel ratio is correct to allow for a clean burn.
black soot out the stack is definatly unburnt fuel and yes the soot does collect in the oil as suspended particals but they are smaller than 2 micron so they just squeeze thru everywhere and eventually end up being drained out in the oil with yer regular changes, as long as yer oil is up to operating temps the oil flashes of and raw fuel that is in the oil so a washed cylender doesnt apply here, the only time a washed cylender is possible is during long idle periods where the oil is at lower pressure and wont flash off as well
Old Mar 10, 2009 | 08:50 PM
392hemix's Avatar
good to know, I love my cummins and don't want to hurt it hahaha
Old Mar 10, 2009 | 11:51 PM
94cummins12v's Avatar
i always would wait for my thermostat to pop before getting over 20psi or rolling heavy coal just for safety purposes, didnt matter mutch becasue i scored the cylander and burnt a pistin
Old Mar 11, 2009 | 04:42 AM
LOGANSTANFORTH's Avatar
your going to need ALOT of fuel before you wash the rings down in a diesel, like insane amounts.....nothing a stock or slightly worked pump can even come close to doing......
Old Mar 11, 2009 | 08:57 AM
392hemix's Avatar
thats basicaly what i figured, but better safe than sorry.....
Old Mar 11, 2009 | 09:05 PM
ykdave's Avatar
cylinder wash is usually related to low combustion/cooling/oil temps which is very common for an engine thats idling low for long periods of time.
When your rolling coal, combustion temps are fairly warm and quickly skyrocket once the turbo lights
Old Mar 12, 2009 | 03:48 PM
392hemix's Avatar
GOOD so i can keep up the black smoke. its fun to go through town and smoke out asswipes from my town.
Old Mar 13, 2009 | 07:10 PM
ykdave's Avatar
fun, till you get a ticket for it
corksil
Jun 30, 2015 06:58 AM
bryan0702
Mar 18, 2015 05:03 PM
Kennyw250
Jan 14, 2015 07:47 PM
Oct 31, 2014 08:10 AM
91 7three
Oct 15, 2014 12:57 PM
