AFC housing
Old Mar 9, 2009 | 09:33 PM
smokedout's Avatar
Default AFC housing
Ok ives done everything but move my afc housing how do you do that?
Old Mar 9, 2009 | 10:00 PM
94 12valve's Avatar
if your talking about moving it foward or back all you have to do is loosen the 4 bolts that hold it on and slide it foward or back
Old Mar 9, 2009 | 10:29 PM
smokedout's Avatar
what does moving it forward help?
Old Mar 9, 2009 | 11:22 PM
HAYMAFIA's Avatar
i dont know exactly what it does but it helps considerably, a little more black smoke but it'll get on down the road. my haul truck had a ground plate and afc all the way forward, plenty of power to move 54,000 lbs way faster than I wanted to drive
Old Mar 10, 2009 | 12:09 AM
94cummins12v's Avatar
it helps by moving the afc arm further forward
Old Mar 10, 2009 | 05:52 AM
94 12valve's Avatar
thus causing more low end fueling along with some extra top end depending on the plate you are running and if the afc is modded or not
jeffersonl
Nov 15, 2015 07:35 PM
xj_crawler
12
Nov 20, 2014 10:17 PM
SMatyac
Nov 4, 2014 10:29 PM
jeffersonl
Oct 25, 2014 06:46 AM
Spiderman
Oct 6, 2014 09:52 AM
