problem with fog lights
Old Mar 9, 2009 | 07:13 PM
outlaw1_gt's Avatar
Default problem with fog lights
2 weeks ago i was on my way home from vixens.. (gentlemans club) and i notice my foglights shut off. yesterday i checked fuses, wires to fog lights and bulbs. everything looks good but no fog lights... any one got any ideas?
bump
Old Mar 9, 2009 | 07:21 PM
Red_Rattler's Avatar
High Tech Redneck
Possibly the headlight switch itself, they are known to be problematic since they run VERY hot. Could be a loose wire off the switch as well. You should be able to trouble shoot the switch with a multi meter. Pop it out and see what you can see.
Old Mar 9, 2009 | 10:38 PM
00' Quad Cab's Avatar
That would be a great place to start, from there I would go out to the power distribution center and check.
Old Mar 16, 2009 | 12:11 PM
Feerless Fred's Avatar
i have the same problem , ill look into it and get back to you in a week or so
Old Mar 24, 2009 | 12:32 PM
19psi's Avatar
i'm sure it's the actual switch. mine is!
Old Mar 24, 2009 | 02:03 PM
Mopar1973Man's Avatar
Fuses? Common check...
Relays? Swap relays with something else. I've seen them fail too.
Bulbs? I've actually lost 2 bulbs at the same time really rare but it does happen...
Switch good? Can be tested at the relay to see if the signal is present.
Old Mar 24, 2009 | 02:54 PM
cumminsdad08's Avatar
i would check bulbs, had a 2 gen dakota and for whatever reason there must have been a short or something and blew both bulbs at the same time. i racked my brain tryin to figure it out. then my wife came out and asked if i tried the bulbs, i laughed, then cause she was right......
Old Apr 6, 2009 | 06:03 PM
outlaw1_gt's Avatar
checked all and found to be switch installed new switch and all is good
Old Apr 6, 2009 | 07:04 PM
High Tech Redneck
Outstanding, glad you got it sorted out.
burndiesel
10
Feb 7, 2023 01:15 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
357DAD
Mar 5, 2015 04:44 PM
carid
Jan 6, 2015 06:28 AM
