Adam's Polishes Visit - Adam's Polishes
Adam's Super Foamy Car Wash Gun
Old Mar 9, 2009 | 02:09 PM
Nitelord's Avatar
Default Adam's Super Foamy Car Wash Gun
Put the FUN Back In Your Car Wash Routine With Adam's Super Foamy Car Wash Gun. More Foam, Not Swirls!
Adam's has teamed Gilmour to bring you the Foamaster II Foam Wash Gun Adam's style! We call it Adam's Super Foamy Car Wash Gun. You'll call it Magic, Amazing, Cool, and just plain old FUN!
The Gilmour Foamaster Adjustable Multi Ratio Cleaning Gun is the best foam gun in the business. When used with Adam's Car Wash Shampoo concentrate, it's even better. Adam's Car Wash Shampoo foams like crazy coming out of the Foamaster Gun, making your car look like it has been playing in a winter wonderland. What a dynamic duo!
The magic in this wash solution is how well it reduces dreaded swirl marks. Simply rinse your car well (the foam gun creates a nice jet stream for rinsing), coat with a thick layer of frothy Adam's Car Wash Shampoo foam, and begin washing from the top down with your Adam's JUMBO Wash Pad (or favorite car wash mitt). Pre-soaking your car with foam helps to loosen the dirt and grime so you don't need to rub as hard to clean.
As you wash, the thick coating of Adam's Car Wash Shampoo foam provides premium lubrication, protecting your paint from wash induced swirl marks. Lubrication is greatly improved over a standard bucket wash because the suds are not watered down with wash bucket water.
Foam Gun Features
* Chemical resistance to acidic or caustic cleaners
* Accurately mixes and sprays foaming chemicals
* Foam generating wand creates a thick, clinging foam
* Fan spray deflector included for disinfectants, etc.
* Durable polymer mixing head with stainless steel screws
* Quick-set dial selects mixing ratio or mixing off setting
* Anti-siphon built into handle
* Detach handle for a powerful spray rinse
* Easy to fill wide mouth, chemical resistant polyethylene quart or half gallon bottle
TIP: Doing a complete detail? Fill your Adam's Super Foamy Car Wash Gun with Adam's All-Purpose Cleaner to foam your wheel wells, undercarriage and engine compartment. Allow the super cleaning foam to dwell for several minutes, then hose away the grime.
Includes a Gilmour Foamaster II Foam Gun, 1-Gallon Refill Adam's Car Wash Shampoo, 1 Adam's JUMBO Professional Wash Pad, and 1 Adam's Great White Drying Towel.
VIDEO - Adam's Super Foamy Car Wash Gun - VIDEO - Adam's Polishes Forums
Here is a video of the gun in use.
Old Mar 17, 2009 | 07:06 PM
2500HeavyDuty's Avatar
we use that same gun to spray chemical on coild to clean them, that gun makes so much suds
Old Mar 18, 2009 | 08:14 AM
Nitelord's Avatar
It's not quite a foam cannon, but pretty close.
I tried it with the All Purpose Cleaner on the under carriage to get rid of salt and road dirt. It worked great...
