1990 f-250 7.3 diesel won't start
Old Mar 9, 2009 | 10:52 AM
rebel13's Avatar
Default 1990 f-250 7.3 diesel won't start
1990 f-250 7.3 dieel wont start on its own but will start by pulling it.
Old Mar 9, 2009 | 12:10 PM
dieselmadscientist's Avatar
glow plugs could have too much resistance and be bad
Old Mar 10, 2009 | 08:51 AM
rebel13's Avatar
thanks ill check them
Old Mar 10, 2009 | 09:37 AM
wildbill's Avatar
2nd glow plugs
Old Mar 10, 2009 | 11:18 AM
Hummin Cummins's Avatar
I gave up on glow plugs on my 6.9 and went to either. Worked great for a few years then the truck was getting harder and harder to start to the point it did take a pull start.
In this case the starter would turn over and crank but it mabey seemed a little slow. Anyways rebuilt the started and that thing starts almost instantly. Over time the starter got slower and slower. Just something to keep in mind if the glow plugs check out ok.
Old Mar 10, 2009 | 12:36 PM
either when you spray it in its cold then when your engine starts its really hot and snaps your top piston rings
Old Apr 14, 2009 | 12:25 AM
opy22's Avatar
Money 7.3 wont start
could be sucking air after you shut it off, or glow plug relay,glow plugs, make sure you dont have any fuel leaks on return lines.
Old Apr 14, 2009 | 12:36 AM
DB Admin's Avatar
Banned
Is your starter bad?
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Baconjosh
8
Dec 11, 2014 03:16 PM
custom7.3
Nov 23, 2014 10:44 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
