i think its a wiring prob..
Old Mar 8, 2009 | 06:26 PM
99cumminpwr's Avatar
Default i think its a wiring prob..
its got to be wiring i replaced the vp lp and the filter now i have fuel pressure on the low pressure side but i only get i trickle on the out of the vp44 going back to the tank....and i only got moisture on the 1st injector(a few drops of fuel)...CHECK ENGINE light is still on and does anyone now anything about what PO253 means NO info in the haynes damn i wish i could get this thing to start........anyone anything Please!!! thx:argh :
Old Mar 8, 2009 | 06:45 PM
busta's Avatar
have you unhooked the line coming out of the lp to ensure it is pumping while running?
Old Mar 8, 2009 | 07:54 PM
Red_Rattler's Avatar
High Tech Redneck
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector) What wiring did you replace?
Old Mar 9, 2009 | 09:53 AM
i only pulled some old plow wiring out of this thing
Old Mar 9, 2009 | 10:03 AM
Whit's Avatar
Site Mascot
is this the OEM lift pump?
Old Mar 9, 2009 | 11:44 AM
same thing as stock just morre gph
oem= 25gph?? i think
allaint= 67gph
nothin drastic just the little bit extra
but the lp is pumping fuel now that i put more fuel in the truck but im only getting a slow trickle out of the vp overflow (tons of fuel at the out of filter) and only drops at the #1 injector and CHECK ENGINE light still on????/?? why???? thanx 4 the help cause i cant figure it out
Last edited by 99cumminpwr; Mar 9, 2009 at 11:44 AM. Reason: Automerged Doublepost
Old Mar 9, 2009 | 11:49 AM
Whit's Avatar
Site Mascot
......................you cant expect alot of fuel out the overflow as it is set for 14psi.................you need to get the truck runnin then check the excess flow from the return line as 80% of the fuel will be returning to the tank , another thing is the VP wont let you get fuel out of every injector line pending on how its lined up, ech time you bump the starter try to bump the motor over just a touch so the injection pump stops at a different point
exactly what did you install for a new lift pump???
Old Mar 9, 2009 | 01:32 PM
wake26's Avatar
you checked the power to the plug at the back of the vp? when you installed the new vp did you plug your throttle postion sensor back in and did you get the pin on the shaft of the vp lined up with the gear inside correctly? I just got done putting on a new vp this weekend that is the code that came up on my truck when the pump went out, it took me about 10min to get all the air out of the lines. we hooked a snapon code reader on after the pump install you will be amazed how many codes it will throw when you start unplugging stuff.
cumminspwr11
12
Oct 17, 2021 03:50 AM
ofelas
11
Aug 12, 2015 07:23 PM
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
Forks diesel nut
Jul 27, 2015 12:19 PM
Mike H
Nov 25, 2014 03:13 PM
