S480 - how much boost is ok????
Old Mar 7, 2009 | 09:25 PM
Camotanker's Avatar
Default S480 - how much boost is ok????
So I have a S480 in a compound twins setup w/ V-clamp. 62/14 on top.
I'm seeing 30psi from the bottom turbo and 60psi overall. How much is optimal to stay within the effeciency range of the s480? 35psi? 40psi? what is the max?
Thanks!
Old Mar 7, 2009 | 09:32 PM
stkdram55's Avatar
id say right around 0-40 psi
reallly dont know bud sorry
Old Mar 7, 2009 | 09:44 PM
Camotanker's Avatar
geeezus. .
wondering if someone has a map or some expertise.
Old Mar 8, 2009 | 12:59 AM
Fishin2Deep4U's Avatar
Originally Posted by Camotanker
geeezus. .
I ahve a map to the shop.
No one has maps for these things. It seems that 32-34 psi is about max before you start seeing drive pressure issues anyway.
Are you going bigger on the secondary? Something like a 64/71-14?
Dave
Old Mar 8, 2009 | 12:02 PM
Camotanker's Avatar
for now i'm not. i want to see what is capable with what i got....
someone has to know what these s480's should be running at for sure.
Old Mar 9, 2009 | 11:26 PM
Austin The DieselTech's Avatar
What do you think you are capable of putting down as of right now?
Old Mar 10, 2009 | 01:41 AM
231jasons's Avatar
Call Nate at MPI he builds 62/s480 twins right?
Old Mar 10, 2009 | 12:03 PM
Red_Rattler's Avatar
High Tech Redneck
Heres your boost map
Old Mar 10, 2009 | 09:51 PM
MRaynor's Avatar
Good job Red.
Old Mar 11, 2009 | 12:20 PM
Camotanker's Avatar
thanks brah!
Any chance you have a map without the "race cover"?
My goal is to figure out what to set my overall boost of the bottom turbo at. Is 45psi safe? Is 50psi safe? Where am I going to get the biggest bang for psi?
Thanks again!
Last edited by Camotanker; Mar 11, 2009 at 12:20 PM. Reason: Automerged Doublepost
