please help vp44 !!???
Old Mar 7, 2009 | 06:58 PM
99cumminpwr's Avatar
Default please help vp44 !!???
replaced the vp44 today and i still have check engine light and truck still doesnt start anyone anything did i just replace vp 4 nothin
:a rgh:
Old Mar 7, 2009 | 07:01 PM
wildbill's Avatar
Was it a used or remand VP??
Old Mar 7, 2009 | 07:02 PM
remand
Old Mar 7, 2009 | 07:10 PM
What kind of Lift Pump you using? Any codes? Hows Fuel Pressure? Did you crack the fuel lines loose and bleed lines?
Luke
Old Mar 7, 2009 | 07:12 PM
Sounds like youre airbound. Do you know how to belled the injectors?
And answer Lukes questions above please.....
Old Mar 7, 2009 | 07:16 PM
ALLAINT fuel pump Fualt code po253 fuel pressure was good than it died down to a trickle
and yea i tried bleeding the lines and then i lost pressure maybe because i only have 1/8 tank fuel?????
i was told to crack the #1 injector and let the lift pump run
Last edited by 99cumminpwr; Mar 7, 2009 at 07:16 PM. Reason: Automerged Doublepost
Old Mar 7, 2009 | 07:20 PM
busta's Avatar
drawstraw with the allaint?
if it is ya might have the same thing i used to come across with the air dog as I drilled my tank wrong and if i was on a hill no fuel when the tank was low
may take more then just one line cracked
Old Mar 7, 2009 | 07:22 PM
now tank drilling just 65gph replacement
no**
Last edited by 99cumminpwr; Mar 7, 2009 at 07:22 PM. Reason: Automerged Doublepost
sounds like a bad lift pump
Old Mar 7, 2009 | 07:32 PM
its brand new 0 miles on it
seems like every one agrees with me hmmmmmmmmm STUMPED
Last edited by 99cumminpwr; Mar 7, 2009 at 07:32 PM. Reason: Automerged Doublepost
