Bad cmp?
Old Mar 7, 2009 | 11:01 AM
paulsatala's Avatar
Default Bad cmp?
Will the camshaft position sensor throw a code if its bad? Is this only used on warm starts? how can this be tested?
Old Mar 7, 2009 | 11:20 AM
wildbill's Avatar
What's the code??
Old Mar 7, 2009 | 11:23 AM
wildbill's Avatar
If it's a low voltage code: time to replace
If it's a high voltage code: got a short or some other sensor caused the code
Rationality code: sensor is reading high, low, and everywhere in between
Old Mar 7, 2009 | 01:30 PM
paulsatala's Avatar
i dont have a code. just wondering if it wiil show one
Old Mar 7, 2009 | 06:26 PM
wildbill's Avatar
If the CEL is on, one will show up. Turn the key on then off three times. On the third key on cycle, read the codes in the odometer window.
Old Mar 11, 2009 | 10:17 PM
coblanchard's Avatar
Why do you think you have a problem with the sensor?
|WYG|SS
Jul 4, 2015 08:31 AM
Gitana
Feb 18, 2015 10:08 AM
Feb 5, 2015 12:10 AM
Mike H
Jan 25, 2015 10:08 AM
12vbomber
Nov 11, 2014 10:58 AM
