Antifreeze
Old Mar 5, 2009 | 09:53 PM
farm boy's Avatar
Default Antifreeze
How do you get the antifreeze out of the block when you want to change it
Old Mar 5, 2009 | 10:11 PM
wildbill's Avatar
Should be a drain plug on drivers side and passenger side, just above the oil pan. Be careful, once it hits the front end, it'll run all over the place. Helps to have a wide/long drain pan.
Old Mar 5, 2009 | 10:27 PM
94cummins12v's Avatar
its on the driver side
to drain the block just pull the heater core line that dips down by he oil filter housing that will drain everything all in one shot
Last edited by 94cummins12v; Mar 5, 2009 at 10:27 PM. Reason: Automerged Doublepost
Old Mar 8, 2009 | 04:33 PM
Hercules's Avatar
If you do decide to take the plug out to drain the block, have something like a small screwdriver handy too. Sometimes crud and corrosion will block the hole not letting the coolant drain when you take the plug out. Just take the and shove the screwdriver into the hole to punch through the corrosion. Just remember it will come gushing out quickly once you clear the way.
jorttel
Feb 22, 2015 09:50 PM
tumble72
Nov 20, 2014 12:31 AM
