pitman arm stuck??
Old Mar 4, 2009 | 09:42 AM
99cumminpwr's Avatar
Default pitman arm stuck??
has anyone else ever broke a pitman arm puller trying to replace the power steering lower seal kit???? an ways to make removing this arm easy besides adding heat thanx,,,,,
Old Mar 4, 2009 | 09:47 AM
Uncle Bubba's Avatar
Not without gettin pretty rough on the steering box. Heat, air hammer or pickle fork and a BFH is the only ways I know of. Good Luck To Ya.
Old Mar 4, 2009 | 09:53 AM
yea i was already beating the hell out of the arm with a air hammer and i put the pitman arm puller on with a 1/2 in ratchet and a 3 ft bar got that as tight as i could then tryed beating it with the air hammer STILL NOTHING and then cranked on the puller and broke it in half......So i just bought 2 brand new pullers last night so now its eitheir gonnna come off or i dont know what to do.....
thanx man ideas are appreicted
Old Mar 4, 2009 | 10:31 AM
spoolinaround's Avatar
your lucky, mine fell off going down the road last fall, on the stubborn ones I have had to use my cutting torch to really put some heat to it and do it fast
Old Mar 4, 2009 | 10:37 AM
Guess if it came down to it I'd have to pull the body grinder out myself and take it off in pieces.
Old Mar 4, 2009 | 10:41 AM
yea thats a good idea i will just get a used one from the junkyard thanx
Mr.Krabs's Avatar
That seems like the best way to do it IMO,all that heat can't be good for the box.
Old Dec 8, 2009 | 09:38 AM
Marine's Avatar
I need to replace mine; doesn't sound like fun!
Old Dec 8, 2009 | 12:49 PM
pepperboy's Avatar
keep the pitman arm puller tight and then take a torch on a low flame and run the flame around the pitman arm with the flame pointin towds the floor and then take up on the puller with a air inpact and it shoul pop off. I know u dont want to use heat but if u do it rite this shouldnt mess up the gear box
Old Dec 8, 2009 | 07:29 PM
ja-mudder's Avatar
just a month ago on a buds 03 cummins I used a puller torxed out to the point i thought it might break and then used a pickle fork on the airhammer and it was a KO in no time
Iv used heat in the past on my ol 78 ford and toasted the seal in the box
