timing question
Old Mar 2, 2009 | 08:58 AM
david dickerson's Avatar
Default timing question
I am new to the whole diesel thing but I am 17 and I have A 98 12v with a number 10 plate 350 horse injectors and a s300g and i dont feel like its making the horse power that it should cause my old motor had the timing advanced 16 degrees and It would turn them over in 4th with 355 gears but now I did an engine swap and didnt know how to advance the timing so its set to stock and in 4th and 5th my charger doesnt light until about 1700 rpms were it used to pick up about 1300 could my timing be the problem ?any advice would be helpfull
Old Mar 2, 2009 | 12:28 PM
Cummins97's Avatar
12v Timing
Timing would help it out some.
Old Mar 2, 2009 | 12:31 PM
12valvetater's Avatar
our dumptruck has a 12 valve in it and it was super sluggish the carger wouldnt light until 1500- 2000. it is all stock but we changed the exhaust gasket and it spools up real fast now. just a thought
Old Mar 2, 2009 | 01:15 PM
94 12valve's Avatar
your sig says you have a super b special thats a 64/71/14. If you do have a super b special 1600-1700 is about where its gonna spool with the stock head and cam.
Old Mar 3, 2009 | 12:09 AM
94cummins12v's Avatar
ok guys what is the factory timing seting on a 12v. i installed the pump and evrything lines up at true top dead center?
Old Mar 3, 2009 | 05:53 AM
94 12valve's Avatar
it depends on what pump the 160-175 pump 12-12.5* the 180-215 13.5-14*
Old Mar 3, 2009 | 10:28 AM
ok thanks i did swap over to the 215 last year so it would be the higher one than, thanks for the info
Old Mar 4, 2009 | 09:42 AM
well when i first put the turbo on there it seemed to spool alot quicker but then I swapped the motors cause the old one had a bad problem with head gaskets but it could just be my imagination
And as a side note I was thinking about getting a 4k gsk and different valve springs because i was told that could be part of my problem that almost as soon as it lights its running out of fuel
Last edited by david dickerson; Mar 4, 2009 at 09:42 AM. Reason: Automerged Doublepost
quiksilver1j
Jul 30, 2015 12:41 PM
cummins Pride
Dec 31, 2014 12:58 PM
12vdriver21
Dec 29, 2014 07:46 AM
SMatyac
Nov 15, 2014 07:35 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
