Rear end problem and tranny issues!!
Old Mar 2, 2009 | 08:51 AM
BigManBrad's Avatar
Default Rear end problem and tranny issues!!
When i go on trips that are 50 miles or more and make a sharp turn or any 90 degree turn. My truck seems to make a wicked noise and leaves rubber on the road! It vibrates my whole truck my mirrors shake and everything! I was told i have a postive rear but i'm not sure! Than the trans issue! It has a billet convertor, and shift kit in it. When the truck shifts at 5 mph it gives me a really good kick and when it shifts at 15 it really gives me a good pow. Is this normal or do you think the valve body it going? The truck has 200,000 miles on it..I'm kinda new to diesels and want to make sure i have no serious problems or any thing.
Thanks guys
Old Mar 2, 2009 | 11:52 AM
01quadcab's Avatar
your lsd might be going out and staying locked up.. have you serviced it ever? on the trans have you had the tv cable adjusted? that makes a huge difference yours may be off or tight as mine was off after changing the apps I didn't clip it on all the way and when I backed off the throttle is shifted really hard
Old Mar 2, 2009 | 02:08 PM
BigManBrad's Avatar
I have never serviced it ever.. I just got the truck a no more than 2 months ago. What is the lsd?? I have also never had the tv cable adjusted. I do know the apps was changed recently though.
Old Mar 2, 2009 | 05:18 PM
MotorOilMcCall's Avatar
Limited Slip Differential... Its a Posi-Trac in other words... Go to Napa and get some Friction Modifier, put a whole bottle int he rear diff and drive around. It'll free up.
Old Mar 2, 2009 | 05:33 PM
BigManBrad's Avatar
Ok thanks for the info i will do that as soon as i get home!!
tim12valve
9
Apr 21, 2015 05:51 PM
Ol' RED!
Dec 11, 2014 10:00 AM
