well e big green is down again.
Old Mar 1, 2009 | 09:54 PM
biged681985's Avatar
Default well e big green is down again.
two weekends in a row my truck has let me down and needed a tow home. but this time it wont be a 16 dollar gasket no matter what it is. i was headed home this morning about 9 a.m. i was doing 60 and started to accelerate at about 1/8-1/4 throttle and hit 65 then bang. knock knock knock knock knock. i got it to the side of the road. it is whte smoking at idle, very low power, and knocking real bad. i pulled the valve cover, push rods are all in correct spots, valves where there supposed to be. pulled intake off and checked turbo, barely any movement on the shaft. thinking its either a headgasket, injecter problem, or the rod bearings are shot. what do yall think.
Old Mar 1, 2009 | 10:28 PM
cumminsman65's Avatar
I think id give up bro aint got a clue but i can help tear it down
Old Mar 1, 2009 | 10:44 PM
xzaq103's Avatar
FormerVendor
12 valve....
Good luck man lmk if I can help
Old Mar 1, 2009 | 11:06 PM
bosshog siad maybe VP-44 or timing gear jumped a tooth?
went out to check to see if it had any blow by, started up, then died. now it wont even try to turn over
Last edited by biged681985; Mar 1, 2009 at 11:06 PM. Reason: Automerged Doublepost
Old Mar 1, 2009 | 11:14 PM
xzaq103's Avatar
FormerVendor
Damn.... Good luck man
Old Mar 1, 2009 | 11:17 PM
good luck? wtf is that. ive never had that
Old Mar 1, 2009 | 11:21 PM
94cummins12v's Avatar
welcome to the club
Bosshogg's Avatar
Ed, the white smoke is what made me think VP. Since its locked up now, its either #6 has welded itself to the wall or the bearings are spun. Either way, start with pulling the pan and checking the pickup for metal. I'll check back with you tomorrow night.
Old Mar 1, 2009 | 11:55 PM
xzaq103's Avatar
FormerVendor
I was thinking #6 earlier
Look at it this way ED. you can build it up for to make more power!
Does that make you feel better?
Old Mar 1, 2009 | 11:56 PM
no need to pull the pan, pull the plg and stick you finger up in it and scrape the bottom of the pan if no metal im thinking it will pee a f'ed up piston and cylander
