3rd gen steel rims,HT60, HX35w core, intercooler piping, exc
Old Mar 1, 2009 | 03:14 PM
spoolinaround's Avatar
Default 3rd gen steel rims,HT60, HX35w core, intercooler piping, exc
I have a set of 3rd gen steel base model rims and center caps with BFG rugged trail 265/75/17 tires, they are about half tread with some weather checking and minor dry rot, I had these on a bobcat trailer, comes with center caps $125
hx35w core, comp wheel grenaded and has bad slop in the bearings $50
HT60 Turbo, good and tight still but when I took the compressor housing off to have it polished I somehow broke the tips off of 2 compressor wheel fins, other then that it is fine and still nice and tight from previous bearing job, comes with 3" v-band 90* to 4" ICpipe adapter $200
I also have a bunch of 3" aluminum .080" wall tubing that I was going to make powdercoated and anodized intercooler pipes with but the deal with the anodizing guy fell through, tubes are 24" long right now $10 each plain or will cut to your legnth and roll a bead on the end for $20
stuff I am looking for: 2nd gen grey driver seat, 2nd gen steering wheel with the airbag horn( I just need the wheel) and a good HX35 with a 12cmwastegated/14cm non wastegated housing or a 8 blade HX40w
Old Mar 7, 2009 | 06:39 PM
anyone? I am open to offers or trades for almost anything
Old Mar 7, 2009 | 06:55 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
Is the compressor cover on the HX35 still good, i need one to machine for my 35/40.
Old Mar 7, 2009 | 10:54 PM
Cumminsdieselboy's Avatar
the HT60, is it still useable or will i have to purchase a new wheel for it?
Also i have an hx-35, 1 stock exhaust housing and one 14cm non wg. only turbo, but 2 different exhaust housings to choose if you wanted to do a trade....
Cody
Old Mar 7, 2009 | 11:29 PM
the 35 is heading to Coaltrain Diesel and I would put a new wheel on the HT if I was going to run it, it is a good tight turbo with no play so why screw it up with a out of balance wheel
Old Mar 8, 2009 | 09:50 AM
Go RAVENS!!!!!!!!!
Are you selling the HX35 or not?
You listed it for $50, as stated above in my post if the comp housing is any good i'll take it.
Old Mar 8, 2009 | 11:47 AM
the HX35 is already sold
Old Mar 9, 2009 | 07:49 PM
