HELP!! NEW South Bend clutch not working!!
Old Mar 1, 2009 | 09:19 AM
dukeboy_318's Avatar
Default HELP!! NEW South Bend clutch not working!!
last night i finished putting my truck back together after upgrading to a South Bend 3250 Double disc, brand new. got it back together, drove it around the block, ran great, pulled into the garage to double check that everything was tight and that nothing was leaking and now the damn thing wont go back into gear, it feels and sounds the like the clutch wont engage, i push the pedal and it has the same pressure it did while driving around the block but its like nothing is happening. any help would greatly be appreciated. thanks in advance.
Old Mar 1, 2009 | 09:30 AM
BlackDodge's Avatar
Did you upgrade the hydro system and where is the pedal releasing at?
Old Mar 1, 2009 | 09:36 AM
no, peter @ southbend told me it would not need the upgrade and that it would be fine without it.
Old Mar 1, 2009 | 02:18 PM
BlackDodge's Avatar
I'm not real sure what's up?? I got a Valair DD with about the same plate load and they sent a upgraded hydro, said that it was recommended?
Does grind when you try and put it in gear?
Old Mar 7, 2009 | 08:07 AM
found out that the shift fork that came in the kit was too thick and it was catching, ground it down a little with a bench grinder, works fine, driven it about 600 miles so far
Old Mar 7, 2009 | 10:39 AM
wildbill's Avatar
Old Mar 7, 2009 | 11:45 AM
BlackDodge's Avatar
Man that was luck. Just installed my DD lastnight and also learned about the shift fork grind down.
Old Mar 10, 2009 | 06:26 PM
glad to help, hehe
Old Mar 10, 2009 | 10:42 PM
Cummins97's Avatar
Did you guys pull out the washer behind the shift fork ball? You are supposed to!
Old Mar 11, 2009 | 05:36 PM
yes, i did
