p pump swap
Old Feb 27, 2009 | 01:13 AM
fastfreddie's Avatar
Default p pump swap
hey guys i have the opportunity to get a 97 12v that was over heated complete. was thinking what everyone thinks ,do a swap. if i have the complete engine for parts the front cover pump gears . is it possible to do a p pump swap without buying a swap kit. as this is a very economical option for me right now. then i can go for the big hp numbers
Old Feb 27, 2009 | 01:53 AM
Yup - should be fairly straightforward if you have all the parts....you might have to buy old bits and pieces.
Have a buddy in Airdrie that did it. Hes a Millwright, so it wasnt too big of a deal for him. He likes it. Put down close to 500 hp with a S-300.
Im just not sure how to make the cruise control work if that is an issue for you.
Looks like all the stuff you need is listed here:
http://www.scheiddiesel.com/display_part/2511.php
Old Feb 27, 2009 | 08:31 AM
Bosshogg's Avatar
You'll have to source injector lines but other than that all the parts should be on the 12V
Old Feb 27, 2009 | 01:08 PM
01quadcab's Avatar
what are you planning on using just the front cover and injection pump setup? If so you will need the injectors setup for the pressure of the ppump and not the vp 44. Great swap I am planning on doing this when my vp goes bye bye. but I think thats soon..
Old Mar 26, 2009 | 08:55 PM
heins's Avatar
yea a p-pump will bolt right on 2 a 24 valve. just need the lines. u will also need the cam senser relocation bracket but other than that u will need. that 12 valve should have everything else
Old Mar 28, 2009 | 03:16 PM
Mr.Krabs's Avatar
I could be wrong,but I think you need the 12V gear case too,or get the VP case machined
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
greenbomb
Jan 23, 2015 10:36 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
