Qaud's 3rd gen Adrenaline is out.
Old Feb 26, 2009 | 07:54 PM
CumminsRig's Avatar
Default Qaud's 3rd gen Adrenaline is out.
As the heading says the Adrenaline has been released. I am sad to say it is only available for 03 to 05. I guess us 06 to 07 guys will have to wait a little longer but I am willing to wait.
Old Feb 26, 2009 | 08:20 PM
stkdram55's Avatar
I didnt think they were gonna be released til the end of march
Old Feb 26, 2009 | 10:05 PM
07redsled's Avatar
here it is looks cool time to dump my xzillaraider 2 Adrenaline Engine Control System
03-05 Dodge 5.9L Cummins
After incredible success with the Adrenaline series of performance modules in the VP44 powered Dodge trucks, developing a Common Rail version was inevitable!
Following in the footsteps of its predecessor, the Adrenaline/Pulse combines so many features into one product it makes your choice easy! With the Adrenaline you get specialized tuning for fuel mileage, towing and all out power. We also give you the ONLY On-The-Fly Custom tuning which lets you adjust the Adrenaline to suit your tastes. With over 160rwhp on tap, the Adrenaline is one of the highest horsepower plug and play modules available.
So how does it all work? With our success in the past, we started with a proven design using Rail Pressure, Injector Pulse Width and Timing as the base for the Adrenaline. We combined our proven design with new technology to allow us to fuel sooner, smoother and harder. More pulse width is also used on the Adrenaline than our previous design, but not so much that it becomes detrimental to exhaust temperature. This combination is unique and allows for smooth, clean power with controllable EGTs. Of course you can change most of this in custom tuning if you want more smoke or want to change the throttle response characteristics.
All Adrenaline/Pulse modules are 100% USB updatable as we continue development. With more tunes aimed at a variety of uses, the Adrenaline will never get old!
The Adrenaline is the most complete engine management system available. Whether you are looking for simple mileage gains with safety features, the best towing performance, big performance that is safe and trouble free, or all out power by adding the Adrenaline to a programmer, this product is for you!
Giving you even more choices, the Adrenaline is available as a base model with a ControlPOD. While most of the features above can still be used, you will be limited to a smaller number of parameters and you will need to change certain things via USB updates instead of the on-the-fly option with the Pulse. With the option of the ControlPOD, you can still have all the power and all the safety features you desire but, you can do it on a budget!
Custom Tuning Options:
# of Power Levels (4-14)
Rail PSI Scale (0-100%)
Max Rail PSI (24000-28000psi)
Rail PSI TPS Max (0-100%) TPS% when you reach Max Rail Pressure
Rail PSI TPS Min (0-100%) TPS% when you start adding Rail Pressure
Boost Scaling (14-30psi)
Fuel Stretch MAX (0-100%)
USB Updatable
160 RWHP Gains
Max Mileage Tuning Level
Built in EGT, Boost, Transmission Temperature Gauges
Built in PowerIdle
Built in Guardian De-fueling Software for EGT , Boost, and Trans Temp
Built in TurboGuard
Rugged Weatherproof Enclosure
Easy Access USB port
Plug and Play Installation
Best Towing Performance Available
Unparalled Throttle Response
Turbo Timer (EGT or Time based)
Cold Engine Protection (User Selectable)
Safety De-Fueling (User Defined)
Transmission Slip Protection
15 Monitored Engine Parameters
0-60 Performance Times
¼ Mile Performance Tests
Parameters Monitored:
-EGT
-Boost
-Rail Pressure
-Fuel Pressure (low side)
-Transmission Slip %
-Gear
-Converter Status
-Coolant Temp
-RPM
-TPS %
-MPH
-Correct MPH
-IAT
-Battery Voltage
-Load %
The Adrenaline is in a class of its own. It has more features, more control, more function, more power, and the most reasonable pricing anywhere!
Part Number: Application: Retail:
ADR1003-PCM 03-04 Dodge 5.9L w/Pulse Monitor $949.00
ADR1004-PCM 04.5-05 Dodge 5.9L w/Pulse Monitor $949.00
ADR1003 03-04 Dodge 5.9L w/ControlPOD $749.00
ADR1004 04.5-05 Dodge 5.9L w/ControlPOD $749.00
let the coal roll
Old Feb 28, 2009 | 05:35 PM
89silverbullet's Avatar
finally
the site says coming soon
Last edited by 89silverbullet; Feb 28, 2009 at 05:35 PM. Reason: Automerged Doublepost
Old Feb 28, 2009 | 06:07 PM
busta's Avatar
in the e-mail I got about it Expected to ship on or before March 31st.
Old Feb 28, 2009 | 06:50 PM
https://www.dieselbombers.com/diesel...drenaline.html
Torkjunky
Nov 20, 2018 08:46 PM
Cdog121
Nov 16, 2015 01:49 PM
CHAMP31707
For Sale
Jun 1, 2015 04:03 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
CGwill
Jan 26, 2015 02:10 AM
