big programer starting problems??
Old Feb 26, 2009 | 07:23 PM
CumminsKid6's Avatar
Default big programer starting problems??
i have a qaudzille adrenaline and when i oput it on my truck it takes almost 30 second or more before itll let me start it. and i took it off and put a smarty on to see if it wouldnt and it also takes forever to start. would anyont know what could be my problem
Old Feb 26, 2009 | 07:29 PM
Mr.Krabs's Avatar
I think you've probably got a fuel leak.
Maybe you pushed a fuel line when you were standing on your head installing the Quad?
Old Feb 26, 2009 | 07:31 PM
i know thats not the problem cause when i took the qaudzilla off itd start just like normal.
Old Feb 26, 2009 | 07:36 PM
Mr.Krabs's Avatar
Oh,my bad.
Old Feb 26, 2009 | 08:52 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
I don't under stand. What is it exactly doing? Cranking for 30 seconds or won't try to start for 30 seconds. do you have the Pulse too?
Old Feb 26, 2009 | 08:58 PM
99dodgeruffrider's Avatar
Default same problem with a torque dog
I could't start my ctd after using my torque dog. It won't set the timing back, only turns half a turn. I disconnect both batterys and reboot the computer, then it starts right up. I called bullydog and they said it was the connections. I tried cleaning them and didn't help. this thing is brand new out of box, but I can't find the receipt. So I guess I'M SCREWED. Im going to try dealing with them. It cost $549. thanks Frank
Old Feb 27, 2009 | 07:08 PM
Mopar1973Man's Avatar
Hmmm... I've heard of problems with some programmers...
But I would check your fuel system for fuel leaks and what your cranking pressure is... You'll see my first pass you see the pump fade out after I let off the key. (air in the line!)
Old Mar 1, 2009 | 04:31 PM
when i dont have a big power programer i wait a few seconds and start it. and everythings good. but if i put either a quadzilla or a smarty on it even with them on stock i have to wait atleast 30 seconds to start it. but i also have a 65 horse edge ez and its just like normal wait 2 to 3 seconds and starts right up.
GasItOut
35
Jul 22, 2015 01:11 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Jun 4, 2015 08:40 AM
Oct 26, 2014 06:20 PM
angies04
Sep 29, 2014 04:11 PM
