Diesel Dawgs Performance Visit - Diesel Dawgs Performance
03-05 Cummins Quadzilla Adrenaline
Old Feb 26, 2009 | 11:21 AM
FormerVendor
Default 03-05 Cummins Quadzilla Adrenaline
Attention Common Rail guys – This is the product for you:
The all new Quadzilla Adrenaline for the 2003-2005 Dodge 5.9L Common Rails!
Taking the valuable knowledge gained through the thousands of VP44 Adrenalines in service, we have gone even further in creating the ONLY on-the-fly custom tuning module ever with 160rwhp! How can you go wrong with the best plug and play module on the market that not only offers tons of extra horsepower but also has the ability to increase your fuel mileage?!
The 2003-2004 and 2004.5-2005 Dodge 5.9L Adrenaline offers:
> 15 monitored parameters
> Turbo Timer (EGT or Time Based)
> Cold Engine Protection (User Selectable)
> Safety De-Fueling (User Defined)
> Transmission Slip Protection
> 0-60 Performance Times
> ¼ Mile Performance Test
If your customer is looking for a more economical version then the Adrenaline with ControlPOD is the option for them. At a $200 savings, they will still get all of the power and safety features they could ever want while staying within a budget!
Hurry and place your pre-orders today – the Quadzilla Adrenaline. Simply the most complete engine management system available anywhere!
Orders placed before March 30th will receive a 10% pre-order discount!
Expected to ship on or before March 31st.
Old Feb 26, 2009 | 11:43 AM
stkdram55's Avatar
Old Feb 26, 2009 | 12:39 PM
Red_Rattler's Avatar
High Tech Redneck
Will this "play" nice with a Smarty Luke?
Old Feb 26, 2009 | 01:09 PM
FormerVendor
Should work good together like the Edge/Attitude. Just be careful with the amount of timing you have both the Adrenaline and Smarty set at.
Here is more info:
Adrenaline Engine Control System
03-05 Dodge 5.9L Cummins
After incredible success with the Adrenaline series of performance modules in the VP44 powered Dodge trucks, developing a Common Rail version was inevitable!
Following in the footsteps of its predecessor, the Adrenaline/Pulse combines so many features into one product it makes your choice easy! With the Adrenaline you get specialized tuning for fuel mileage, towing and all out power. We also give you the ONLY On-The-Fly Custom tuning which lets you adjust the Adrenaline to suit your tastes. With over 160rwhp on tap, the Adrenaline is one of the highest horsepower plug and play modules available.
So how does it all work? With our success in the past, we started with a proven design using Rail Pressure, Injector Pulse Width and Timing as the base for the Adrenaline. We combined our proven design with new technology to allow us to fuel sooner, smoother and harder. More pulse width is also used on the Adrenaline than our previous design, but not so much that it becomes detrimental to exhaust temperature. This combination is unique and allows for smooth, clean power with controllable EGTs. Of course you can change most of this in custom tuning if you want more smoke or want to change the throttle response characteristics.
All Adrenaline/Pulse modules are 100% USB updatable as we continue development. With more tunes aimed at a variety of uses, the Adrenaline will never get old!
The Adrenaline is the most complete engine management system available. Whether you are looking for simple mileage gains with safety features, the best towing performance, big performance that is safe and trouble free, or all out power by adding the Adrenaline to a programmer, this product is for you!
Giving you even more choices, the Adrenaline is available as a base model with a ControlPOD. While most of the features above can still be used, you will be limited to a smaller number of parameters and you will need to change certain things via USB updates instead of the on-the-fly option with the Pulse. With the option of the ControlPOD, you can still have all the power and all the safety features you desire but, you can do it on a budget!
* Custom Tuning Options: # of Power Levels (4-14)
* Rail PSI Scale (0-100%)
* Max Rail PSI (24000-28000psi)
* Rail PSI TPS Max (0-100%) TPS% when you reach Max Rail Pressure
* Rail PSI TPS Min (0-100%) TPS% when you start adding Rail Pressure
* Boost Scaling (14-30psi)
* Fuel Stretch MAX (0-100%)
* USB Updatable
* 160 RWHP Gains
* Max Mileage Tuning Level
* Built in EGT, Boost, Transmission Temperature Gauges
* Built in PowerIdle
* Built in Guardian De-fueling Software for EGT , Boost, and Trans Temp
* Built in TurboGuard
* Rugged Weatherproof Enclosure
* Easy Access USB port
* Plug and Play Installation
* Best Towing Performance Available
* Unparalled Throttle Response
* Turbo Timer (EGT or Time based)
* Cold Engine Protection (User Selectable)
* Safety De-Fueling (User Defined)
* Transmission Slip Protection
* 15 Monitored Engine Parameters
* 0-60 Performance Times
* ¼ Mile Performance Tests
Parameters Monitored:
-EGT
-Boost
-Rail Pressure
-Fuel Pressure (low side)
-Transmission Slip %
-Gear
-Converter Status
-Coolant Temp
-RPM
-TPS %
-MPH
-Correct MPH
-IAT
-Battery Voltage
-Load %
Old Mar 16, 2009 | 01:49 AM
07redsled's Avatar
yha i gona wana get one from u lukesdiesel by the way will it work good with my bullydog?
Old Mar 16, 2009 | 01:51 AM
FormerVendor
You won't need the Bully Dog unless you need a paper weight
Old Mar 16, 2009 | 01:30 PM
07redsled's Avatar
yah i got a custom turn called pressure larry so stack the two in it should really fly
Old Mar 16, 2009 | 01:34 PM
GRI's Avatar
GRI
I will be beta testing this. so keep an eye out on the forum here to see what my results are.
Old Mar 16, 2009 | 07:43 PM
FormerVendor
Old Mar 16, 2009 | 09:16 PM
07redsled's Avatar
hey GRI that thing roll coal??????
