killing your rear tires
Old Feb 25, 2009 | 08:37 PM
392hemix's Avatar
Default killing your rear tires
Just got the my 12 valve back on the road, now that i dont have to worry about the KDP, i can put the ***** to the wall! I have a quick question, to save my breaks and blow out my tires, has anyone installed a hurst line lock? i would like to put one in, but didnt know if it would be dificault due to the strange master cylinder on these 97 dodges?
Old Feb 25, 2009 | 08:41 PM
12valvetater's Avatar
good question but i have no idea. if you dont want your breaks to work take the shoes off for your burnout and then put them back on later. i dont know if that would mess up the cylinders or not though
Old Feb 25, 2009 | 08:50 PM
392hemix's Avatar
Yea, im not sure, i put the line lock in my 68 road runner and it works the *****, i just don't really know how it would work on that strange power boost break system?????
Old Feb 25, 2009 | 10:43 PM
97 D-Tec's Avatar
you should be able to just do it w/o the line lock .. its easier i think w/ a single wheel. im going to try it on my dually when the tires get really worn
Old Feb 25, 2009 | 10:49 PM
392hemix's Avatar
I can burn my tires off now, but i don't want to destroy my rear breaks in a burnout contest! the truck hammers down.....even with the sure grip/ limited slip. anyone put a line lock in one of these trucks??????? maybe a manual praportion valve?
Old Feb 25, 2009 | 11:07 PM
toy4xchris's Avatar
never done either of those but don't see why they wouldn't work.
can't you just un-adjust the rear brakes probably a lot cheaper and easier
Old Nov 7, 2009 | 11:50 PM
Biggy B's Avatar
Old Nov 8, 2009 | 06:45 AM
440ctd's Avatar
you will leak fluid from the wheel cylinders if you take the pads off. as well as blow the seals out. I would run un adjusted rear brakes but they will prolly catch anyway but not as hard
Old Nov 8, 2009 | 06:47 AM
cummins95's Avatar
pullin the shoes off is a bad idea, without them in there as soon as u touch the pedal u'll blow the pistons right out of the wheel cylinders. might wanna try adjustin them all the way off. and i dont see any reason why a line lock wouldn't work.
Old Nov 8, 2009 | 07:50 AM
monster12valve's Avatar
