'98 QC SB 12v
Old Feb 25, 2009 | 12:38 AM
I-6DZL's Avatar
Default '98 QC SB 12v
Red 98 QC SB 12v 4x4
First and foremost the truck is not in perfect shape (body wise)
Guages are Di-Pricol Trans temp, EGT, and Boost with black face. Fuel pressure guage is in ash tray with Stainless steel tubing running inside the cab.
Driveline
DTT transmission - Cryo'd input, 91% single disk converter, Mag Hytec Double Deep pan.
12v engine
DDP 3 injectors - less than 3k miles.
PDR hx40
ATS manifold slightly ported on both head and turbo sides
4" exhaust with muffler and 6" tip
Flex-A-Lite fans
Brand new Interstate batteries (both)
AFE filter and heat shield
3:55 gears
New rear brakes (very grabby tho)
Upgraded to the 1 ton chevy wheel cylinders
Brand new Moog steering components
New Moog balljoints
Lukes link on trac bar
New Rancho shocks, front and rear
Drilled and slotted Raybestos front rotors with Raybestos heavy duty pads
Body
Rusted front doors, PO slid into a tree with the LF door and fender.
Bed - wheel wells are rusting out, and has a dent (from a deer) on the front Left side that could probably be pushed out.
Tail gate - Few small dents from a broken chain
Rear bumper - couple good sized dents
Front bumper - needs replaced or aligned with body.
This truck also has a brand new B&W goose neck hitch that I installed and NEVER USED. Also comes with an AGR steering box PO said it was used very little. 3 sets of rims and tires. Set 1 285/75/16 BF Goodrich AT's Less than 5k miles on factory steel wheels. Set 2 265/75/16 mud tires that are pretty worn out on factory steel wheels. Set 3 285/75/16 unknown manufacturer (will check and update) pretty good tread mounted on Factory 2nd gen Alloy wheels without center caps.
That's all i can think of right now, i'll update i remember something.
I will only communicate through email
12vdzl@live.com
$$$$13,200 OBO with everything listed above. I am located in Southern MI and will pick you up at Lansing, or detroit metro airport. Can help with delivery. Don't be affraid to make a solid offer, i have a good sense of humor
partial trades possible, but must be a smokin good deal for me.
Old Feb 25, 2009 | 12:40 AM
Red_Rattler's Avatar
High Tech Redneck
Any pics?
Old Feb 26, 2009 | 12:40 PM
I-6DZL's Avatar
Yes sir, what's your email?
BTW truck has around 150K miles
Old Feb 26, 2009 | 12:43 PM
High Tech Redneck
Old Feb 26, 2009 | 05:28 PM
I-6DZL's Avatar
Pics below.
Pictures by 12vdzl - Photobucket
Also, the truck has tow mirrors, 3k gsk, and #4 fuel plate.
Old Feb 28, 2009 | 12:53 AM
I-6DZL's Avatar
Someone make an offer, whatever you feel the truck is worth......
Old Feb 28, 2009 | 02:00 AM
spoolinaround's Avatar
you said make an offer... I would give $8k for it ya cause thats whats left in my savings account
Old Mar 1, 2009 | 12:22 AM
I-6DZL's Avatar
LOL A little higher and you may have yourself a deal!
Old Mar 4, 2009 | 03:14 AM
I-6DZL's Avatar
10,500 Lets deal......
Old Mar 10, 2009 | 09:09 PM
I-6DZL's Avatar
bump
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
Tory4
For Sale
Feb 1, 2015 08:33 PM
StreetRat
8
Jan 15, 2015 03:45 PM
cummin_not_strokin
Dec 31, 2014 03:28 PM
Oct 30, 2014 08:10 AM
