1997 12 valve broke the sensor above crank shaft
Hello, i just fixed the killer dowel pin on my 1997 12 valve, as i was putting the harmonic balancer on i did not notice the sensor above was improperly located and it broke :-( is this a Crank postion sensor? and where do i get one? How do i instal it correctly? is there a measurment or gap between the balancer and the sensor? also what does this thing do???? i am new to diesels and electronics. P.S looked for this part all over and it seems like no one talks about it or sells it online, or maybe i just don't know how to type it in the search engine? Thanks for any help!!!!!
Thanks, i guess i know what i am buying from auto zone. Do you know how that is ajusted? or does it just bolt up? i would imagine that you would use a feeler gauge to adjust? P.S Thank you for your fast reply, i am very new to this and am enjoying the site
well, i guess i will never make that mistake again 108.00 bucks, that not cheap, can i drive the truck without that? i didnt even want to try or even start it untill i knew what that sensor did? you said it just controls the tac?
on a 12 valve the only thing you need for the engine to run is fuel pressure (mechanical lift pump), power to the starter so it'll spin over, and power to the shutoff solenoid to allow fuel in the pump. IIRC that is all these motors NEED to run.
I have that sensor off of a 94 CTD. I thought it went out and replaced it but it turned out to be the tach in the cluster, and they wouldn't let me return it.
I don't know how to PM but I will try to PM my contact info
Hey Guys, got the truck back on the road, my friend had a spare engine with the sensor and gave it away for 25 bucks!! now the truck is better than new and i don't have to worry about the KDP!!!! ***** TO THE WALL
