DAMPER on way out,where to get new one?
Old Feb 24, 2009 | 08:52 AM
will1am's Avatar
Default DAMPER on way out,where to get new one?
where can i get a new crankshaft damper balancer?my old ones rubber is crumbling on the outside...should i go factory or used?there is a used one i can get from a 98 24valve...will this work on my 12 valve?
thanks
Old Feb 24, 2009 | 10:00 AM
RSWORDS's Avatar
I woudl go new. Some stuff you just should not buy used. Try our vendors they might be able to get you a good deal on an aftermarket that will work better then the stocker.
Price Quote - Request A Price - Diesel Bombers
Old Feb 24, 2009 | 10:35 AM
Cummins97's Avatar
If you decide to go used I have one off of a 2000 I'd sell cheap.
Old Feb 24, 2009 | 11:14 AM
LOGANSTANFORTH's Avatar
Fluidampr.......
Old Feb 24, 2009 | 11:19 AM
12valvetater's Avatar
will a 24 valve damper even work 12 valves use the damper to tach off of
Old Feb 24, 2009 | 11:11 PM
94cummins12v's Avatar
rubber on the damper? mine is solid steel
Old Feb 25, 2009 | 01:45 PM
the ring yes but the damper wouldnt be a damper if it was just a hunk of steel it needs rubber or fluid to let the weight of the ring balance out the crankshaft vibrations.
Old Feb 25, 2009 | 10:48 PM
97 D-Tec's Avatar
fluid dampr all the way. save your self the money and getsomething that will last should you decide to start building the truck up
Old Feb 26, 2009 | 02:16 AM
you can build upa truck on a stock damper, mines stock, alot of guys are stock, some sled pullers are stock
12Vdodge
8
Dec 15, 2015 01:00 AM
