bed lined rockers
Old Feb 23, 2009 | 08:23 PM
12valvetater's Avatar
Default bed lined rockers
the previous owner of my pickup had these big stupid looking steps on after i took them off i realized that he had drilled holes in the rocker panels. the holes held water and they have started to rust its not bad yet but i want to fix it before it gets any worse. my buddies 24 valve had the rockers rhino lined up to that seam where the paint changes color and it looks really good. i was wondering how much it would cost to do that and what all would be involved with it? can i do it myslef?
Old Feb 23, 2009 | 08:27 PM
Whit's Avatar
Site Mascot
they charged me 375 to do mine...........I like it alot however I wish I had come up and over the wheel wells too
Old Feb 23, 2009 | 08:34 PM
94cummins12v's Avatar
did mine for $70 with the duplicolor stuff and its held up to all the elements
Old Feb 23, 2009 | 08:37 PM
thats what mine looks like did them last winter
Old Feb 23, 2009 | 08:43 PM
that does look good. hows it hold up to rocks coming off you tires?
duplicolor? where do you get it how much a quart was it?
Last edited by 12valvetater; Feb 23, 2009 at 08:43 PM. Reason: Automerged Doublepost
Old Feb 23, 2009 | 08:46 PM
it was $70 at napa for a gallon and that was with aplicator kit (pan, brush, roller for the liner) it holds up great dont chip when fenders get dented, holds up great to the abuse i give it in the mud hole with no mud flaps on the front tires
Old Feb 23, 2009 | 08:55 PM
do you have to do an prep work to the paint first? a gallon was enough to do the whole thing? do you roll it on or brush it on?
Old Feb 23, 2009 | 08:59 PM
a gallon was enouph to do 3 coats first then 2 coats a day later for durability, i used the roller because it has a special texture pattern, throw the brush away, you do have to sand the areas to be sone and then wash with hot soapy water. i did mine in my shop at 65*, make sure you tape it off so they are straight lines
Old Feb 23, 2009 | 09:01 PM
would 2 gallons be enough to do the the rockers and the bed?
Old Feb 23, 2009 | 09:05 PM
depending on how many coats you do, i dont see why not, im going to hit my bed this summer
