idling her up!
Old Feb 22, 2009 | 10:17 AM
smokedout's Avatar
Default idling her up!
Whats the good and the bad about idling your truck up and how do you do it?
Old Feb 22, 2009 | 10:44 AM
Cummins97's Avatar
What's it at now?
Here's a pic of where you adjust it. Just loosen the nut then loosen the bolt to idle it up. Then tighten the nut back.
Old Feb 22, 2009 | 11:34 AM
94cummins12v's Avatar
if its a manual you want it to idal at abot 850 if its a 5 speed you want it abut 700-800
Old Feb 22, 2009 | 12:27 PM
Beets's Avatar
Old Feb 22, 2009 | 12:30 PM
Originally Posted by Beets
whats that supposed to mean
Old Feb 22, 2009 | 12:37 PM
Beets's Avatar
read what you said if its a manual you want it to idal at abot 850 if its a 5 speed you want it abut 700-800
you said manual then 5 speed. same thing you ment to say auto fro one "Right?"
Old Feb 22, 2009 | 12:39 PM
oh woops, that might be an issue, thanks for catching that, i thought you was saying i was worng.
ok revised" if its a auto you want it to idal at about 850 if its a 5 speed you want it abut 700-800"
Old Feb 22, 2009 | 12:49 PM
Beets's Avatar
your welcome i saw that and was rubbing my head
Old Feb 22, 2009 | 01:49 PM
Cummins97's Avatar
Good catch!
Old Feb 22, 2009 | 05:05 PM
haulitrite's Avatar
Turning up the idle higher isn't good for a auto trans because in slams into gear a bit too hard, and if your truck is a manual it will want to roll alot faster w/o touching the pedal.
turning it up isn't a good idea
