Running cold
Old Feb 20, 2009 | 03:41 PM
Dieseldog92's Avatar
Default Running cold
My 92 d-350 has been running cold for a couple weeks. The temp gauge will barely lift off of c no matter how long i run it. And the heater wont work. I was thinkin it could be the thermostat or heater core?
Old Feb 20, 2009 | 03:57 PM
Heath's Avatar
Authorized Amsoil Dealer
Sounds like a stuck thermostat?
Old Feb 20, 2009 | 04:42 PM
RSWORDS's Avatar
X2
Old Feb 20, 2009 | 07:42 PM
Nevflatbed's Avatar
That's exactly what that is. Replace it with a good thermostat and you will be warm and happy!
Old Feb 20, 2009 | 07:45 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i agree with all the above
Old Feb 25, 2009 | 01:54 PM
Greg G's Avatar
Ya know that the Thermo might just be the problem. But - did you also check the level in the radiator? If you happen to have a leak in the cooling system and loose antifreeze. A low coolant level will do the same thing.
Old Feb 25, 2009 | 02:38 PM
RSWORDS's Avatar
Good point.
Old Feb 26, 2009 | 09:00 AM
My water pump leaks so im constantly adding coolant. Im sure it is the thermostat but how much of a hassle will it be to change? On my blazer i can do it blind folded
Old Mar 25, 2009 | 08:02 PM
scrambler500's Avatar
you could have a short in the gauge thats what to me
Old Mar 26, 2009 | 12:03 AM
94cummins12v's Avatar
if the heater was working then it might be a short in the guage, the temp sender dont effect the heating, change the t-stat and you should be good
