help truck won't start
was hedding home yesterday and was coming to a stop and the truck died, pulled over and put the truck in park and all it does now is turn over will not start. you can har the air dog pumping the fuel and I didn't get a check engine light at all either. any suggestion on what might of happened?????
I aint any expert but i was taught since birth all a diesel needs to run is fuel and air, work it backwards from both ends and you should find the problem. prolly aint no help.
runnin good before it died?
Are you sure you are getting fuel to the injection pump? My guess is you are not. If you are, it's most likely the VP44 that is the culprit. If you are getting fuel to the injection pump, you need to crack the injector lines to see if you are getting fuel to the injectors. Welcome to Dieselbombers by the way, sorry your first post has to be for help.
mishkaya
mishkaya
I agree with Mishkaya................crack injector lines 1,3,4 and bump the starter to trigger the air dog.......do this 3 times the tighten the lines down and re-start..............give 1/4 throttle and start it up
getting fuel to IP but no further nothing comes out of the injecter lines. throws code p0253. the reader says to test the pins 6&7 on the plug on the back of the IP. we have power on 7 but nothing on 6. any body have any Ideas. yea full tank
po253 code is open circuit to fuel injection pump.......aint good
I say go back out there and try again, crack inj lines 1,3,4 and bump starter to move some fuel, tightem em back up and try to start with 1/4 throttle...................if its got fuel than it will run
mishkaya
