help tranny problems
Old Feb 17, 2009 | 09:15 PM
bigrich's Avatar
Angry help tranny problems
ok 91 250 4x4 with a 5.9 cummins.it has the 4 speed auto tranny. i just rebuilt it with new evreything tc and all.i replaced the throttle positioning sensor and the speed sensor on the tailshaft. the truck runs fine in all gears but then when im in od it starts acting up. it seems to free rev like its going into kickdown so i have to let off and get back in it and its fine but it could happen 10 times in 15 miles. i think its the tv cable shot out please help thanks rich
Old Feb 17, 2009 | 09:23 PM
RSWORDS's Avatar
did you adjust the kick down cable?
Old Feb 17, 2009 | 11:06 PM
Begle1's Avatar
You should be able to check articulation of the TV cable easy enough, right? Have a helper push the throttle to the floor and back while watching to see if the shaft on the transmission moves?
Our trucks don't have a kick-down cable.
Old Feb 17, 2009 | 11:24 PM
bigrich's Avatar
Default i tried it
yes there is adj in the cable but it just goes right back to the end of adj. i adj it and it works good for a day or two and it just goes right back to crap hense the reason i think its the tv cable. i dont have a kickdown its just hammerdown and go
Old Feb 20, 2009 | 09:56 PM
bigrich's Avatar
so i got the tv cable replaced and its doin the same thing it did before not as intense but its still doin it.just drove it home from the tranny shop.im wondering if it needs to be adj or if somenthing else is wrong.could it be the rearend speed sensor?please help thanks
Old Feb 21, 2009 | 07:14 AM
RSWORDS's Avatar
Did a shop rebuild it for you? Carry it back!!!
On another not could teh TPS be going out? I dont drive a OD tranny so I'm at a loss.... Sorry.
Old Feb 26, 2009 | 10:09 PM
93/250's Avatar
TPS sensor, mine did the exact same thing. Clean the plug and try it again.
Old Feb 26, 2009 | 10:42 PM
bigrich's Avatar
ok i just got it back from the tranny shop again and he hooked it up to the scanner he said that the tps was gettin alot of noise from somewhere. electrical problem.i think its my battery cables they are pretty jacked up,frayed. the neg cale is the worst of the two.he just told me to check all my connections and tighten/clean them all. what do you think
AHAAN
Jul 19, 2015 10:28 PM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
Ol Goat
Jan 22, 2015 02:16 AM
TNTPrime
Jan 5, 2015 06:13 PM
corey352
94-98 7.3L Performance
Oct 22, 2014 10:58 AM
