Power Steering Pump?
Old Feb 17, 2009 | 09:47 AM
Jazz's Avatar
Default Power Steering Pump?
Is there some type of blow-off valve on the power steering pump? Thursday morning I left on a trip at 4:00 am and as I was traveling my power steering pump started growling so when I stopped and it was daylight I couldn't see anything wrong so added some fluid and all was well. My wife calls me and says are you all right and I said yea why. She told me I left a huge stain in the driveway. Well when I got home sure enough it was power steering fluid but once I filled it no leaks. So is there some type of blow-off valve? Something freeze?
Old Feb 17, 2009 | 10:57 AM
stkdram55's Avatar
good pre-trip inspection by the way i dont think so there is, check your lines they could be leaking but very little
Old Feb 17, 2009 | 11:05 AM
01quadcab's Avatar
mine did this before I switched to the amsoil universal power steering fluid due to the cold. Since then no issues
Old Feb 17, 2009 | 12:47 PM
MotorOilMcCall's Avatar
Willing to bet your shaft seals are shot. I had the same thing happen in the 99 before I bought it from the company. Within 2 weeks of us getting it the pump started leaking a ton. Sure enough, the shaft had play and was leaking right outta there.
Old Feb 17, 2009 | 06:13 PM
Jazz's Avatar
Bite me!
I had no problems when I fired up in the morning, Just when I started to leave. I use to go through all that DOT crap. I still check things out but have no idea why this happened. I checked more today and still don't see where the fluid came from
Old Feb 17, 2009 | 11:53 PM
stkdram55's Avatar
Old Feb 18, 2009 | 12:14 AM
94cummins12v's Avatar
my shaft seal on my stearing box has leked from day one just ad a qt of fluid every month
b&hbiz
Sep 9, 2015 07:53 AM
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
moneypitk5
Feb 12, 2015 11:01 AM
sweetv8s10
Oct 7, 2014 09:47 PM
