filter relocate
Old Feb 16, 2009 | 09:20 PM
94cummins12v's Avatar
Default filter relocate
has anyone built there own fuel filter relocate setup yet im going to build one but an not sure how to run the lines, i was thinking of using copper tubing with flared fittings but wasnt sure if the banjo conections could be flared since there steel lines
Old Feb 16, 2009 | 09:24 PM
Cummins97's Avatar
Be sure to take pics of the project!
Old Feb 16, 2009 | 09:41 PM
Racer9's Avatar
It's been done; PRIME-LOC - FUEL FILTER RELOCATION KIT ('94-'96 DODGE)-Dodge Cummins and Ford Power Stroke Diesel Truck Accessories - Geno's Garage
I like DIY'ers, and do a lot of my own mods. I would use rubber lines myself. Less chance of breaking from vibration.
Old Feb 16, 2009 | 10:33 PM
What Racer said - get some good quality Marine rated diesel hose, put a filter down by the tank and your done.
FYI, Vulcan performance sells the line. (3/8" supply and 5/16" return, OR you could do a 1/2" big line kit - whcih Vulcan Performance also sells).
You could look at a Racor type fuel filter - http://www.go2marine.com/category.do?no=13766&mfrno=316
Also here:
http://www.o-f-i.com/index.php?page=...separators.htm
Old Feb 16, 2009 | 11:43 PM
thanks for the help guys im going to keep it in the engine compartment for show purposes, i was thinking about getting some blue fuel line, cut the bajo fitting off then splice in the hose were the pipe was and mount it on the reont of he head instead of the rear
one question if i were to use the rubber stuff from the lift pump to the filter housing would the line be able to stand the pressure? aslo what is the max pressure from pump to housing?
Last edited by 94cummins12v; Feb 16, 2009 at 11:43 PM. Reason: Automerged Doublepost
Old Feb 16, 2009 | 11:48 PM
The blue hose is good for 300 psi I believe....
The kit from Vlucan is more than just hose - its a big line fuel kit just like those available for the 24V's...it includes everything you need and I believe it included bigger fittings for better flow.
12V Fuel System Upgrade
I am not certain if it includes the supply/return lines all the way from the tank.
Old Feb 16, 2009 | 11:55 PM
im not exacly looking to improve the flow as much as i am versitility by accresing the filter easyer and show purposes this engine pops right now im just trying to make it stand out even more. i will buy some of the blue 1/2" for the supply line and then the 5/16" for the return line, im drawing up a braket to be able to mount it to my intake elbow
Old Feb 17, 2009 | 08:28 AM
Racer9's Avatar
The fuel pressure is under 40psi. Stainless braided would look way cool!
Old Feb 17, 2009 | 09:27 AM
ive got steel braid on everything else for oil lines and most fuel lines im thinking blue is the color im wanting
gone ropin
17
Dec 3, 2017 06:31 AM
jeffersonl
Nov 15, 2015 07:35 PM
Bob V
Apr 6, 2015 11:02 PM
jeffersonl
Oct 25, 2014 06:46 AM
james2562
Oct 8, 2014 06:14 PM
