Tip wont Fit - Ideas?
Old Feb 15, 2009 | 07:12 PM
DPowell5.9's Avatar
Default Tip wont Fit - Ideas?
i recently put 5" exhaust on my 06. i got a silverline 5- 6in tip to go with it. the tip wont fit. its almost like either the pipe is a little bigger than 5, or the tip is a little small. ive got the screw backed out all the way loose on the tip. anybody had a problem like this? i tried wd-40, didnt really help. just wanted to see if anybody had any ideas before i just return the tip.
Old Feb 15, 2009 | 07:59 PM
midnite><og's Avatar
cut a small slit in the pipe from th truck, then get some radiator hose and screw it together. the space occupied by the slit will eventually close and then the tip should slip on. then remove the radiator hose. hope you understand that, and hope it works!
Old Feb 15, 2009 | 08:01 PM
Hut's Avatar
Hut
Don't know anything about it but couldn't you cut the pipe square to length and weld it on?
How far off is it?
Old Feb 15, 2009 | 09:05 PM
Red_Rattler's Avatar
High Tech Redneck
Get a good set of oven mitts and stick the tip in the oven at 350 and heat it up. No specific time, just get it good and hot and it should expand enough to slip it on. Let it cool down put the bolt back into the tip and snug it up!
Old Feb 15, 2009 | 09:26 PM
Originally Posted by Red_Rattler
Get a good set of oven mitts and stick the tip in the oven at 350 and heat it up. No specific time, just get it good and hot and it should expand enough to slip it on. Let it cool down put the bot back into the tip and snug it up!
while you do that, cool down the pipe your puttine it on (wrap it in icepacks, ice, dry ice, w/e)..... cant belive i didnt say that
Old Feb 15, 2009 | 09:28 PM
DPowell5.9's Avatar
i dont want to weld the tip on because i might want to change it later. im gonna try that oven trick though.. it wont damage the stainless finish at all will it?
Old Feb 15, 2009 | 09:46 PM
High Tech Redneck
Nope
Old Feb 16, 2009 | 06:49 AM
HOLYSMOKES's Avatar
NADM Member
More than likely one might be 5"ID and and the other 5" OD?
Old Feb 16, 2009 | 04:16 PM
1Tondiesel's Avatar
Your tip won't fit?? Sounds like a personal problem. Maybe you should find a bigger girl.
Sorry, couldn't help it.
Old Feb 16, 2009 | 04:19 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i would get it replaced
