lift pump rebuild?
Old Feb 14, 2009 | 04:38 PM
zjohnsonua's Avatar
Default lift pump rebuild?
The lift pump went out on my dad's 12v yesterday and after replacing it we took the old one apart to see what went bad in it. It turns out the only thing bad was a couple little spring loaded seals at the end of a big spring. Anyone know of a rebuild kit thats available? I really dont want to spend the 120 bucks on a new lift pump if theres a kit out there. My 12v has a weak one and i want to fix it before i get stuck workin on the truck for 3 hours from changing a fuel filter...
Old Feb 14, 2009 | 06:47 PM
Cummins97's Avatar
Never seen a rebuild kit... There may be one out there tho.
Old Feb 14, 2009 | 06:50 PM
ykdave's Avatar
never came across one yet...
Which is kind of retarded because it is usually just a seal or sping in them that goes out. mind you, if you shop around you can get the pump failry cheap
Old Feb 20, 2009 | 01:51 AM
Never seen one either
Old Feb 20, 2009 | 11:24 AM
94cummins12v's Avatar
nothing
Old Aug 30, 2010 | 02:42 PM
strokercummins's Avatar
Interested in knowing more about the Cummins (Carter) lift pump? We made hundreds of tests on the Cummins fuel system and we are sharing the information with diesel owners. The article is 3 1/2 pages long and features actual flow data that you may find useful. Please share the info with other P pump owners.
Rob Parelli
AKA Strokercummins
Here is the link
Tork Teknology Article Number One- The Cummins Lift Pump
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
