Blower Motor - bad sounds
Old Feb 13, 2009 | 08:03 PM
Jesse James's Avatar
Default Blower Motor - bad sounds
90% of the time when my blower for the heater and A/C, in the cab of my 2005 ram has a whine or a loud HUMMM, it getts louder the higher speed itd on. Has any one else had this problem and what was it. I think its the blower motor going out, thanks
Old Feb 14, 2009 | 01:02 AM
wildbill's Avatar
Got a bushing that's burned up.
Old Feb 20, 2009 | 01:39 AM
cummins tech's Avatar
PULL UR BLOWER MOTOR AND LOCK INSIDE OF IT. MICE LIKE TO GET UP IN THERE AND PUT THINGS IN THE BLOWER MOTOR. THIS WILL CAUSE THE BLOWER MOTOR TO BE OUT OF BALACNE AND MAKE FUNNY NOISES
Old Oct 7, 2009 | 09:18 PM
ARAJRR's Avatar
remove the blower motor and look in it there is a door that breaks inside duct, I've seen three so far I need to know what the door does myself.
Old Oct 15, 2009 | 01:01 PM
wolfpack's Avatar
That is what I'm guessing too, the blend door was broke on mine when I bought it. It was $25 and about 20 minutes to change it out.
Old Oct 15, 2009 | 02:38 PM
12vcummins96's Avatar
sounds like the motor has a bad bushing
Old Oct 18, 2009 | 11:00 AM
richie waddell's Avatar
my 06 done something very similar so i pulled the motor out and when i did i found one of the directional doors had broken off and fell down in front of the wrong air way
Old Oct 19, 2009 | 06:52 PM
workhard.playhard's Avatar
I had the same thing happen to my '06. One of the hinges on the blend air door broke off and fell into the basket of the blower fan which caused the whole cabin to sound like an airplane. The good news is Dodge makes a whole new piece to replace the existing door. The bad news is you have to take the whole dash apart to replace it. I started to do it myself and could not donate the time it takes to complete the job. I took it to our mechanic and he had five hours into the job. Unless someone else found an easier way to fix it, it's not cheap.
Old Oct 25, 2009 | 08:29 PM
wolfpack's Avatar
You have to buy the whole housing from Dodge, but you only have to replace the door to fix it. The housings are identical and just changing the door and servo was about 25 mins. and that was with testing and putting the tools away.
Old Oct 26, 2009 | 05:58 PM
Interesting...the Dodge dealership told me that they had a lot of problems with the '06 blend doors and so they redesigned the housing so the problem would not happen again. I don't even know you, but for some reason I trust you more then the dealership. There is $500 bucks out of my pocket in labor. What a crock!!!
realtrucksrattle
Sep 20, 2015 10:24 PM
Aug 7, 2015 12:40 AM
cdetterer
Jan 22, 2015 08:38 PM
7.3_powerhouse
9
Jan 17, 2015 02:22 PM
Floydfan38
23
Nov 2, 2014 03:42 PM
