DPF FOOLERS
Old Feb 12, 2009 | 04:56 PM
1985johndeere's Avatar
Default DPF FOOLERS
I put a DPF delete pipe on my truck but it didnt come with any foolers. Sooo my friend looked it up for me and said we can use resistors and it works the same. Is this true and if so what resistors? And if it dont work where can i buy just the foolers?
Thanks for any and all help
Old Feb 12, 2009 | 05:14 PM
ETXBlueRam's Avatar
Not sure whose delete pipe you have, but you would probably be best off talking to whoever made your kit. They should be able to get you fixed up. I'm sure somebody else will chime in before too long.
Old Feb 12, 2009 | 05:29 PM
I got my pipe off ebay and it is made by flow pro. SO i wont have any help there.
Thanks
Old Feb 12, 2009 | 06:18 PM
cbrahs's Avatar
you will if you want to
can get em fer ya
Old Feb 13, 2009 | 12:02 AM
what kind of foolers are they and how much for them
Thanks
Old Feb 13, 2009 | 12:46 AM
need help 6.7's Avatar
talk to cbrahs he is very helpful and gets you your stuff quick trust me i know hes good and thanks again chris
Old Feb 13, 2009 | 01:09 AM
Thanks for recomending him. Hopefully he can take care of me and get me everything i need for my truck. Im kinda new at this whole diesel thing. And coming into it new with a 6.7 doesnt help any.
Old Feb 13, 2009 | 09:31 AM
JTProuhet's Avatar
I helped him with the DPF delete, and was wondering, someone said that the resistors dont work... But my question is we put reistors in the back 2 senors and the one closest to the turbo is still installed.. IF the reistors didnt work, wouldnt he get a code for 2 senors? my thinking is, we put 680ohm resistors in the 2 plugs we took out.. i had done a lot of reading before we did this and had alot of guys putting 1k in the front and then 680 in the back.. but then i also read that someone took apart the H&S foolers and said they were just 320ohm resistors wrapped in some plastic.... So what i am thinking.. we should go to radioshack and get some 320ohm resistors and stick in there.. I was messing with his truck last night, checked the codes and it was only throwing the egr code for being unplugged and the DPF pressure code for the pressure box being unplugged... so we started it up and let it run for probably 15min and no other codes showed up... We did the key cycle trick, and no codes popped up so... Someone please chime in if i am wrong or not... Go get some 320ohm resistors and stick in them??
Old Feb 14, 2009 | 08:03 PM
cbrahs can u get them foolers and how much
Thanks
Old Feb 14, 2009 | 09:03 PM
diggerdave's Avatar
there called simm plug and play ,,theres 3 of them and they work great? i have the complete flo-pro system and its awsome love it...you can get them from purecummins.com
