Dmax Leaking ATF
Old Feb 11, 2009 | 05:30 PM
kazairl's Avatar
Default Dmax Leaking ATF
I've got a friend of mine that has an early Dmax(I think. I really have no clue what year it is.) It is leaking ATF out of the front of the tranny. From up in the bellhousing. I'm thinking tat one of the seals on the front pump or maybe around the converter is leaking?
Anybody else have some suggestions? We are going to be pulling the tranny soon to check it out. Sounds like its going to be a PITA. But we shall see!
Old Feb 12, 2009 | 12:05 AM
2500HeavyDuty's Avatar
when u do pull the trans, hope this helps
https://www.dieselbombers.com/durama...r-allison.html
Old Feb 26, 2009 | 10:50 PM
hondarider552's Avatar
get a picture and post it up. could be a number of things..
Old Mar 3, 2009 | 03:51 PM
beach_33's Avatar
it is probably one of the bolts that holds the bellhousing to the case. i cant remember exactly which one. i know it is one of the bottom. anyway it needs to have a copper washer put on it. simple fix
Old Mar 3, 2009 | 04:00 PM
wildbill's Avatar
Sounds like your going to have to pull the torque converter anyway. I'd go ahead and change the front seal out, just to avoid it going later.
Old Mar 3, 2009 | 05:23 PM
kazairl's Avatar
well It is fixed. Luckily I wasn't involved.
Turns out it was one of the seals around the TC. Simple fix once they got it down.
|WYG|SS
Apr 28, 2015 03:59 PM
gunman41mag
The Sportsmen's Lounge
Mar 12, 2015 03:46 AM
ChevyGuyForLife
Chevy/GMC Duramax 06-07 LBZ
Jan 13, 2015 12:29 PM
dieselbred
Dec 21, 2014 03:14 AM
Stox5225
Nov 18, 2014 01:04 PM
