Vulcan Performance Visit - Vulcan Performance
Draw Straw V updated again!
Old Feb 9, 2009 | 12:20 AM
Fishin2Deep4U's Avatar
Default Draw Straw V updated again!
We have added the last piece of the puzzle for the in tank pump owners.
We now have 3 basic options in the DSV.
DSV Basic kit. This uses the factory feed tube at the top of the module with 3/8" hardware and fuel line. This kit is aimed at the non bypass pump owners. Instalation is remarkably simple and everything you will need is included.
DSV HiFlow kit. This kit requires NO HOLES TO BE DRILLED IN THE TANK. It does require a hole in the top of the module. Again, 1/2" internals. A simple 5/8" hole is drilled into the module top and uses our special sealing fitting to keep the fuel where it belongs.
DSV HiFlow Upgrade Kit.
This uses larger 1/2" draw tube and hardware. Again, easy install in the module and this setup uses a DSII fitting that came with your Airdog/ Rator of FASS kit. These are for DSII fittings that have already been installed in the tank.
All of our kits feature bio and veggie oil compatible line, easy installation with no broken parts and the highest quality in the market.
Thank for your support of Vulcan Diesel Performance!
Dave
Old Feb 9, 2009 | 12:29 AM
stkdram55's Avatar
Old Feb 9, 2009 | 12:30 AM
2500HeavyDuty's Avatar
these for what truck?
Old Feb 9, 2009 | 12:38 AM
Any truck that has a dealer retrofit or factory in tank pump.
We'll have lots more soon!
Dave
Old Feb 18, 2009 | 03:00 AM
Here's a couple of pictures to help illustrate what's going on with the module.
First, we have the DSV installed in the module in place of the factory pump. This does NOT require breaking of the module or parts just in case the owner would ever want to swap back. Please note, the green line was used for photo contrast and would not be used with the shipped product. The hose we ship is clear and is bio and veg oil compatible. The green line is not. Also, we now go to the top of the module bypassing the bar in the center. New photos will be more clear.
The second images is with an old prototype module that we used to mockup the DSV Hiflow kit. As you can see, everything mounts in the module. The DSV in the base is the same design as the first picture. However, it is 1/2" internally.
Dave
Old Aug 10, 2010 | 04:10 PM
kerley's Avatar
Do you ship these units completely assembled as a new replacement upgraded unit ready to install. Thank you, Tom
Old Aug 10, 2010 | 10:21 PM
RAW's Avatar
RAW
They sure do!
DrawStraw V HiFlow
Old Sep 6, 2010 | 12:11 PM
Budgetbuilt's Avatar
I have a 1998.5 truck and my sending unit broke. I had bought air dog and was going to have to put a draw straw in anyways. Will this setup work? Any help would be appreciated Thanks
Old Sep 6, 2010 | 12:33 PM
RAW's Avatar
RAW
If you need a new sending unit I suggest the Liberty sending unit with DSV installed.
DrawStraw V HiFlow
Old Sep 6, 2010 | 12:38 PM
So this will work fine for a replacment? I didnt no if it was just for the trucks already converted to in tank setup. Thanks
