No power and lots of white/gray smoke
Old Feb 8, 2009 | 08:09 PM
haulitrite's Avatar
Default No power and lots of white/gray smoke
I had the problem with the fuel delivery about a month ago. I took it into a shop and they told me that it was the p-pump.
I purchased a rebuilt pump from one of diesel bombers vendors and installed it.
I test drove it for several days to make sure that I installed it right.
After I was sure that I did it right I started to bomb it.
Ground fuel plate to #0 and slid full forward
slid the AFC full forward
I drove it for about 10 miles and put it trough its paces and it ran fine. But then all of a sudden it lost all power and seems to miss above 1000 RPM. It idles rough and has alot of white/gray smoke.
The oil and coolant are clean.
The truck is a 94 CTD, auto trans.
Old Feb 8, 2009 | 09:09 PM
stkdram55's Avatar
lift pump???
Old Feb 8, 2009 | 09:13 PM
haulitrite's Avatar
Would the lift pump cause the exhaust to burn white?
Old Feb 8, 2009 | 09:16 PM
Benjamin's Avatar
Bombardier
what were your exhaust temps during your
"running it thought it's paces"?
did you make sure the governor arm wasn't going under the fuel plate?
Old Feb 8, 2009 | 09:17 PM
Benjamin's Avatar
Bombardier
any excessive blowby coming out of the blowby tube?
Old Feb 8, 2009 | 09:18 PM
stkdram55's Avatar
wouldnt that make it stick wide open if the arm stuck??
Old Feb 8, 2009 | 09:22 PM
Benjamin's Avatar
Bombardier
no it would it run like crap. the gov arm is different than the rack that tends to stick very rarely....
Old Feb 8, 2009 | 09:29 PM
stkdram55's Avatar
oh my bad i was thinking of the rack
Old Feb 8, 2009 | 09:32 PM
haulitrite's Avatar
Ok, There isn't alot of blow by from the blow by tube.
I don't know how to check the governer arm. I did change the fuel plate to the stock one.
Benjamin's Avatar
Bombardier
what about the exhaust temps. do you have gauges?
