truck stalls?
i am having a problem with my 2002 ram 3500, i will being driving and it will stall not even for a second and then comes back to life by itself....i noticed it only does it when its cold after it reaches full temp it never does it, at first it did it to me one time and then i didnt have a problem now today it did it to me 3 times within 2 miles....im confused i got codes P0606, P1693,P0500. im not sure some of these may be from the time i had lift pump failure , unless they clear themselves after so long of running normal.....thanks
Andrew
Andrew
hmm
P0606 = pcm processor fault
P1693 = Manufacturer contrl auxiliary inputs auxiliary outputs
P0500 = veh speed sensor A malfunction
this is what I get for them
someone with more knowledge will chime in I`m sure
steady 15psi like normal....there is times when it is cold out normally 30 degrees and below when i first start it, it will be around 12 psi for a few minutes then it goes to 15psi.... i have an airdog and theres about 8,000 miles on my filters.
thanks
thanks
