so and ho injection ????
Old Feb 8, 2009 | 10:09 AM
CumminsKid6's Avatar
Default so and ho injection ????
i have an so motor and in process of getting new injection pump. will an ho pump work on so computer or would i have to get it flashed to an ho. or buy an ho computer
Old Feb 8, 2009 | 11:22 AM
Whit's Avatar
Site Mascot
the HO and SO pumps willnot cross..............so I have read
anybody know more bout this???????
Old Feb 8, 2009 | 11:34 AM
01quadcab's Avatar
you don't want the ho pump.
Old Feb 8, 2009 | 11:48 AM
dukeboy_318's Avatar
yes, from experience, an HO pump will not work on a SO engine with an SO ECM, dont try it, waste of money. it has to do with the programing and internal setup of the HO pump which cannot be altered, and you cant get a flash to turn a SO ECM into an HO, only way itd work is if you try swaping the ECM to an HO ECM which will help, ive got one brand new for an 01-02 HO 24 valve, if you decide to go with the HO pump, pm me if interested.
Old Feb 8, 2009 | 02:59 PM
kazairl's Avatar
Besides the SO pump has bigger plungers inside so it will make more horse power than an HO pump. Most HOs are tapped out at about 500 ponies.
Old Feb 8, 2009 | 03:00 PM
Ya you can't run a HO pump on a SO motor but I have ran SO pumps on a HO motor.
Old Feb 9, 2009 | 06:22 AM
i think you may have to run different injectors as well, something with the lift pressure settings is different
Old Feb 9, 2009 | 08:56 AM
kazairl's Avatar
It is a little different. The injectors on an HO are slightly smaller too. and the engine runs a bit more compression.
Old Feb 10, 2009 | 08:36 AM
i thought so, i know my buddy put a brand new HO IP on his 98.5, put a tst PM3 on it, only made 245 hp max on the dyno, we then spent a whole day and a half tinkering with it before switching it out for a new SO one and he broke 350 hp,
Old Feb 10, 2009 | 10:29 AM
so in other words not worth doing unless i get an ho computer.
