hx or hy
Old Feb 7, 2009 | 06:46 AM
Sigel's Avatar
Default hx or hy
i have a 2001 ram 3500 with auto. i thought the hy's all had a built in boost elbow, mine has a seperate elbow. has it been changed to a hx or is it reall an hy. how can i tell? thanks
Old Feb 7, 2009 | 08:05 AM
wildbill's Avatar
Boost elbow is threaded in to the compressor housing. Has something to do with the ability of adjusting opening pressure??
Just a little bit of info for ya:
Autos have the HY for faster spool up. They also have less air output.
Manuals have the HX for the increased air flow, which is why some swap out the HY to an HX for cooler EGT's.
One draw back though, the HX has slower spool up.
Old Feb 7, 2009 | 08:15 AM
Sigel's Avatar
my elbow is clamped on and spools up around 1600
Old Feb 7, 2009 | 10:00 AM
wildbill's Avatar
The hose will be clamped to the elbow, and the elbow will be threaded into the housing. As far as being able to tell which one from what, I'm not sure.
Old Feb 7, 2009 | 10:04 AM
Sigel's Avatar
thats what im saying, the elbow is clamped on both ends. i belive it to be a hy. the exhaust side has the built in turn down and i think hx's are a seperate part. why cant they just put a dang number on the side of the thing
Old Feb 7, 2009 | 10:10 AM
wildbill's Avatar
The hose will be clamped at the waste gate and at the elbow.
Old Feb 7, 2009 | 10:31 AM
connermcpherson's Avatar
i had a hy and it is a piece. the hy doesnt have a rubber boost line, it is metal and is threaded into the compressor housing and into the wastegate actuator.
if you have and 01 or 02 auto, you have an hy35
Last edited by connermcpherson; Feb 7, 2009 at 10:31 AM. Reason: Automerged Doublepost
Old Feb 7, 2009 | 02:40 PM
Sigel's Avatar
i agree it should be an hy. im the third owner of this truck and not sure what has been done before. but my compressor housing dumps out at 90 degrees from inlet and there is a clamped on elbow that turns it 90 degrees to the intercooler
Old Feb 7, 2009 | 03:33 PM
01quadcab's Avatar
take a picture and post it up
Old Feb 7, 2009 | 07:41 PM
ya pic and post
