really starting to make me mad now
Old Feb 6, 2009 | 11:24 PM
sawmillman's Avatar
Default really starting to make me mad now
I have been having trouble out of my rear hub only on one side.It ether backs the axle to hub bolts out or breaks them off I've tried to use studs it just cleans them off.And tonight 6 grade 8 bolts backed out and 2 broke in the hub.I've used loc tight no go lock washers don't help any suggestions would be appreciated.Btw I'm using 7/16 bolts is this the correct size or are the metric? This all started after me being lazy and letting a shop put a new seal in the hub he broke all the bolt off and had to drill and tab the holes out. I guess thats what I get for letting someone else to work on my junk.
Old Feb 6, 2009 | 11:44 PM
94cummins12v's Avatar
i know factory size they are metric but if they drilled and taped them who knows what size they are
Old Feb 7, 2009 | 10:59 PM
sawmillman's Avatar
Quick up date lost the outer bearing on that wheel today so I decided to some investigating,it seems that the moron who drilled and taped the hubs decided to do a quick and dirty job and left parts of the old bolts in the bottom of the holes no wonder the bolts kept coming loose so I'm fixing his crap job and goning to visit him on Monday hopefully this will fix the problem.
Old Feb 7, 2009 | 11:16 PM
97cummins's Avatar
Make sure you have all the old parts you took out of the hub so you can back up the refix you had to do to your truck.
Old Feb 8, 2009 | 01:10 AM
oh boy that sounds like fun give him hell
Old Feb 8, 2009 | 04:53 PM
sawmillman's Avatar
Yea lost a day of work screwed a axle nut have to call the stealer and git one plus the end of the axle shaft is 5 thousands mushroomed split the bearing when I tried to tap it on .Hmm wonder what else can got wrong?
dskewes14
Sep 14, 2015 09:19 AM
GasItOut
35
Jul 22, 2015 01:11 PM
Jul 21, 2015 06:50 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Apr 30, 2015 01:10 PM
