Overfull on Transmission Fluid.
Old Feb 5, 2009 | 10:21 PM
xzaq103's Avatar
FormerVendor
Default Overfull on Transmission Fluid.
What are your thoughts on overfull transmissions? Anyone know of any problems it can cause?
Old Feb 5, 2009 | 10:43 PM
Camotanker's Avatar
the 2nd gear band adjustment has an allen/nut... the fluid will leak from this location.
if its really full, it will leak out of the weep hole at the very top of the transmission above the input shaft.
dont' ask how i know
fluid gets hot or boils, it will shoot out the dip stick and start a fire.
Old Feb 5, 2009 | 11:05 PM
oglejust's Avatar
im not sure if they have a drain plug or not but if not u need to suck it out thru the fill tube. y take a chance?
Old Feb 5, 2009 | 11:10 PM
jnicewan's Avatar
it will puke out what it doesnt want. but it has to be pretty darn overfull. if you dont mind making a little mess just start it up and loosen a cooler line and let some out. being overfull is alot better than under.
Old Feb 6, 2009 | 12:00 PM
4x4_guy's Avatar
the easiest way to get trans fluid out without taking the pan off or loosening any lines is to buy a suction gun($6) and connect a long clear rubber hose to it and suck the trans fluid out of the trans dipstick tube till you get the correct fluid level
Old Feb 6, 2009 | 12:05 PM
Seen that happen at the track.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
PD4Life
Aug 24, 2015 08:11 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
02Stain
Feb 17, 2015 10:21 PM
smokee
Nov 7, 2014 07:40 PM
